A4 B6 2.5 TDI: Replace Fuel Injector Pump
Torrn
Post26-05-2018, 16:21    Subject: A4 B6 2.5 TDI: Replace Fuel Injector Pump Quote
hello
Since it seems the fuel injection pump on my A4 is defective, can anyone tell me how to re-calibrate or "learn" the new pump?
Should I use VCDS to read any data from the old pump, which might be helpful for configuring the new pump?
Thank you in advance.
Translated on 07-09-2026, 2:24.
Post26-05-2018, 19:43    Subject: A4 B6 2.5 TDI: Replace Fuel Injector Pump Quote
As always, Autoscan, what's your engine code?
Translated on 07-09-2026, 2:25.
dieselschrauber likes this.
Post29-05-2018, 11:19    Subject: A4 B6 2.5 TDI: Replace Fuel Injector Pump Quote
If you don't have a login code for the WFS (Workshop Information System), you'll need to have your car towed to a VW/Audi dealership to have it programmed. Unfortunately, that's the only way.
Unless you're lucky and have one of the early B6 models, which still had IMMO II, in which case nothing needs to be programmed.
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Switch LMM: How to Change Your LMM Diesel Engine Technology
No new posts Change Transmission Fluid: DIY Guide & Tips Diesel Engine Technology
No new posts zahriemen AJM wechseln Diesel Engine Technology
No new posts Glow Plug Replacement 1.9 TDI AVF Diesel Engine Technology
