Golf 4 MFA Reset Button: How To Reset
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
F B
Post26-05-2018, 6:41    Subject: Golf 4 MFA Reset Button: How To Reset Quote
Hi.
Below the windshield wiper lever, there is a reset button that is not working.
With the switch next to it, I can browse through the MFA (Multi-Function Analyzer), but because the reset function doesn't work, I can't switch between memory slots 1 and 2, let alone delete a memory slot.
I then simply bought a new windshield wiper arm.
During the installation, I noticed that the left cable connector was in place, but it wasn't properly locked.
Nevertheless, I installed the new windshield wiper arm.
Result: The reset button still doesn't work.
Can I query the function of the button somewhere in VCDS?
'Where exactly?'
Which cable/color connects from the button to the dashboard?
Try installing a different speedometer as a test.
How else could I proceed with this problem, which isn't exactly a matter of life or death?
Best regards, Frank.
Translated on 08-10-2026, 17:19.
Post26-05-2018, 18:46    Subject: Golf 4 MFA Reset Button: How To Reset Quote
Hello Frank,
There's a bitfield in the VCDS diagnostic data blocks from the engine control unit related to the cruise control lever, and it's likely a similar mechanism exists in the instrument cluster for the same function.
Translated on 08-10-2026, 17:20.
F B
Post31-05-2018, 6:23    Subject: Golf 4 MFA Reset Button: How To Reset Quote
Hi.
You do NOT mean in the extended measurement data.
I can't find the cruise control there, nor the wiper/control buttons on the instrument cluster.
Does anyone have a tip for me about where I might be able to find it?
I'll check again later.
Translated on 08-10-2026, 17:21.
Post31-05-2018, 9:09    Subject: Golf 4 MFA Reset Button: How To Reset Quote
Hello Frank,
I think I've described it correctly, but it seems like you're not very familiar with VCDS, judging by your post.
Support for VCDS is only available to customers or with a vehicle diagnostic support key.
Translated on 08-10-2026, 17:22.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
