VW Golf 4 TDI: Turbocharger Problems & Overheating
Malossi136
Post16-06-2018, 6:55    Subject: VW Golf 4 TDI: Turbocharger Problems & Overheating Quote
Hello everyone.
A few weeks ago, I bought a Golf 4 (1999) with the 110hp AHF engine for my sister-in-law. It's her first car, and it was supposed to bring her joy. However, it's slowly driving me crazy.
The golf course was inexpensive, but it required a lot of work.
I replaced the clutch and flywheel. The old starter motor also came out at the same time.
Now, let's talk about the problems.
Nach Kupplungstausch hatte der Golf keinen Ladedruck mehr. Vtg wurde kontrolliert. It was easy to use.
The problem was a loose connection on the vacuum pump, so I replaced it. The check valve was also faulty and has been replaced. I also proactively replaced the mass airflow sensor (Bosch) because I wanted to avoid any further issues.
I went to the TÜV (German technical inspection agency) yesterday. Everything was okay with the exhaust emissions, but...
"This thing is still having those brief interruptions at 3000 RPM; it pauses for about 2 seconds and then kicks in again. It also smells too hot, and the exhaust pipe, including the turbo, has a strange light color. I'm worried that the engine will fail if I can't find the problem."
The only error code showing is related to the cold start injector, indicating a sporadic short circuit to ground. I've tested the part and the resistance values are within normal range. The wiring has also been checked for breaks or shorts all the way to the control unit.
Could it be that this valve is constantly injecting fuel and the engine control unit (ECU) is trying to compensate?
I would be very grateful for a tip.
Sure thing! Please provide the German text you would like me to translate into English. I will only provide the translation without any explanations.
Patrick.
Translated on 07-08-2026, 12:41.
Post16-06-2018, 8:33    Subject: VW Golf 4 TDI: Turbocharger Problems & Overheating Quote
To assess the condition and function of the particulate filter system, diagnostic access to the engine control unit is essential.
As you have surely read in the terms of use ( icon_wink.gif ), a vehicle diagnostic support key is required for PCI, Auto-Intern, and DRV customers to provide diagnostic assistance on diesel engines.
You can also obtain the Diesel Mechanic License, which also includes KDataScope and KPower. icon_idea.gif
From then on, feel free to continue the discussion here.
Translated on 07-08-2026, 12:44.
Malossi136
Post16-06-2018, 10:02    Subject: VW Golf 4 TDI: Turbo Problems & Overheating Quote
Hello Rainer!
Thank you for the quick response.
"If I buy the diagnostic kit, will it only work for cars manufactured from 2008 onwards? Mine is a 1999 model. Also, it doesn't have a DPF."
Translated on 07-08-2026, 12:45.
Post16-06-2018, 10:50    Subject: Golf 4 TDI Turbo Problems: Overboost & Heat. Quote
Malossi136 wrote:
Hello Rainer!
If I buy the diagnostic kit, will it only work for cars manufactured from 2008 onwards? Mine is a 1999 model. It also doesn't have a DPF.
Unfortunately, it doesn't work with the '99 model (which does not support OBD2). However, the support key can be used as credit at any time for any product in the shop. For example, a HEX-V2 or, as listed under "Sales" in the forum, a used HEX-USB+CAN.
Translated on 07-08-2026, 12:47.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Alle Bremsen heiß am Golf 3. BKV einstellbar? Transmission, Chassis, Body & Interior
No new posts Ladedruckregelprobleme! Diesel Engine Technology
No new posts Motor umbebaut ( von AGR auf ASV ) Ladedruckregelprobleme... Diesel Engine Technology
No new posts AFN is trending Diesel Engine Technology
