SeasonApparel
Joined: 08/07/2018 Posts: 3 Karma: +0 / -0 Location: Auenstein
07-08-2018, 21:22 Subject: VW Touareg 3.0 TDI / Ignition not starting |
Dear forum members,
After a long period of suffering with my beloved VW Touareg, I'm posting here in the forum, hoping that someone can give me some advice.
Unfortunately, neither VW nor any other qualified personnel were able to help me with my problem.
About the vehicle:
VW Touareg.
3.0 TDI Automatic.
176 kW.
1. Market introduction: December 2007.
Mileage: Approximately 150,000 km.
"For the past year, I've been dealing with a problem where my car unlocks with the keyless entry system, but it won't start when I press the start button/key." The ignition isn't working, and the display only shows a bird's-eye view of the car.
The first time this happened to me, the tow truck driver was able to help me quite quickly, or he had a suspicion about what was causing it. He quickly disconnected the battery, and voila, everything worked perfectly again (he didn't know why, but it was supposedly a "Touareg problem").
Unfortunately, this error has occurred sporadically four times in the past year. Despite analysis using VCDS, consultation with qualified personnel, and online searches, I haven't been able to identify the cause, and I'm tired of having to carry a toolbox around with me to disconnect the battery every time.
I would appreciate your help.
Christian
matthiasTDI96 Profi-Schrauber
dieselschrauber and SeasonApparel likes this. |
07-08-2018, 21:36 Subject: VW Touareg 3.0 TDI / Ignition not starting |
Then, let's have him perform an auto-scan for us.
SeasonApparel
08-08-2018, 19:23 Subject: VW Touareg 3.0 TDI / Ignition not starting |
Sure, see the attached file.
Thank you very much.
| Description: |
 Download |
| File name: |
Log-WVGZZZ7LZ8D045178-148260km.txt |
| File size: |
20.03 KB |
| Downloaded: |
844 times |
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
08-08-2018, 19:58 Subject: VW Touareg 3.0 TDI / Ignition not starting |
Cause:
Quote: | 2 error codes found:
049493 - Control unit for switch panel installation.
U0155 - 004 - No communication - Intermittent.
Environmental conditions:
Error status: 00100100
Error priority: 6
Error frequency: 2
Lost Counter: 255
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 9.65 V
Binary value: 00000000
(no unit): 8.0
Binary value: 00000001
049682 - Control unit for steering column electronics.
U0212 - 002 - No communication - Intermittent.
Error status: 00100010
Error priority: 6
Error frequency: 2
Lost Counter: 255
Time: 0
Speed: 0 RPM.
Speed: 0.0 km/h
Last: 0.0%
Voltage: 9.65 V
(no unit): 8.0
Binary value: 00000001 |
Profile PM WWW Garage |
SeasonApparel
08-08-2018, 21:47 Subject: VW Touareg 3.0 TDI / Ignition not starting |
Thank you for the quick response. Could you please provide a bit more detail, as I'm not an expert in this field.
Is it possible that the control unit is defective in this case? Or would the entire steering column need to be replaced?
I would be very grateful if you could provide more details. Unfortunately, I am unable to reach Dr. [Name/Title]. Don't search too much on Google.
Christian
Erbse78
08-08-2018, 22:19 Subject: VW Touareg 3.0 TDI / Ignition not starting |
Hello.
To the best of my knowledge, the entire steering column needs to be replaced because the steering column and the control unit are integrated into a single unit. I have experienced problems with Audi Q7 models on several occasions.
gnasch Blaumann
Joined: 07/19/2014 Posts: 78 Karma: +23 / -0 Location: CH-25xx
dieselschrauber likes this. |
09-08-2018, 16:07 Subject: Expensive solution |
It could very well be caused by a loose connection in the wiring.
I would first have this thoroughly checked.
Otherwise, the classic Windows solution might work: reboot.
https://de.wikipedia.org/wiki/Batterieschalter
Ch.
