Particulate Filter Failure: Causes & Solutions
StyLeZP
Karma: +0 / -1   Thank you, like it!
Post06-08-2018, 20:40    Subject: Particulate Filter Failure: Causes & Solutions Quote
Hello everyone.
I drive an Audi A7 3.0 TDI (245 hp). It currently has approximately 172,000 km on the odometer and has had an *** chip tuning installed since the beginning (approximately 300 hp).
MKB: CDUC
The car is driven quite rarely, and when it is, it's usually only for long distances (more than 500 km). However, when it is driven, it's driven frequently over those long distances. Short trips are virtually never done.
"Recently, after starting the engine, an error message appears saying "Particulate Filter System Malfunction." It's also noticeable that the engine is running in a limited mode (it doesn't rev above 1500-2000 RPM and lacks power)."
After restarting the engine, everything returns to normal without any loss of power or other issues - only the yellow preheating lamp flashes. The message then disappears. Sometimes, the lamp is also off again (after a several-hour driving break).
Here's the error memory from the engine control unit. I've read quite a bit about it, and I'm now going to replace the differential pressure sensor, mostly because it seems to fail frequently, and secondly because it's the only sensor error that has been detected multiple times.
I also tried to capture some measurements, but honestly, I can't really make much sense of them. Maybe you can see something in the data, or tell me what I should be measuring.
Based on the driving profile, the mileage, and the oil ash volume reading of 0.21, I don't believe the DPF is full.
Code:
Montag,06,August,2018,19:01:56:13611
VCDS Version: DRV 18.2.1 läuft auf Windows 10 x64
http://shop.dieselschrauber.org/en
                Adresse 01: Motorelektronik       Labeldatei: DRV\059-907-401-V2.clb
   Steuergerät-Teilenummer: 4G0 907 401 F    HW: 4G0 907 401
  Bauteil und/oder Version: 3.0TDI EDC17  H37 0002
                 Codierung: 1A25401A046601020800
            Betriebsnummer: WSC 02311 785 00200
              ASAM Datensatz: EV_ECM30TDI0114G0907401F 001002 (AU57)
                       ROD: EV_ECM30TDI0114G0907401F.rod
                      VCID: 264593CA59D226747B-8072
7 Fehlercodes gefunden:
5168 - Signal Höhengeber/Ladedrucksensor
          P1592 00 [032] - unplausibles Verhältnis
          Sporadisch - unbestätigt - geprüft seit letzter Löschung
5188 - Dieselpartikelfilter - Russbeladung zu hoch
          P2463 00 [096] - -
             Umgebungsbedingungen:
                    Fehlerstatus: 00000001
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 3
                    Kilometerstand: 171456 km
                    Datum: 2018.08.05
                    Zeit: 17:05:54
                    Motordrehzahl: 1592.00 /min
                    Normierter Lastwert: 71.0 %
                    Fahrzeuggeschwindigkeit: 49 km/h
                    Kühlmitteltemperatur: 55 °C
                    Ansauglufttemperatur: 31 °C
                    Umgebungsluftdruck: 890 mbar
                    Spannung Klemme 30: 14.040 V
                    Verlernzähler nach OBD: 40
                    P Flt Ld fac Ash Cor: 0.8500
                    Differenzdruck Partikelfilter: 152 hPa
                    Exh t Adap T Oxi Cat Ds: 616.6 °C
                    Exh t Adap TP Flt Ds: 565.9 °C
                    Abgasvolumenstrom im Partikelfilter: 333.9 m³/h
                    Aktuelle Betriebsart_2-Bits 0-7: 0
                    Aktuelle Betriebsart_2-Bits 0-7: 1
5245 - Geber für Kraftstoffdruck (G247)
          P0192 00 [032] - Kurzschluss nach Masse
10065 - Luftmassenmesser (G70)
          P0104 00 [032] - kein Signal
5268 - Geber 1 für Abgastemperatur (G235)
          P0545 00 [032] - Kurzschluss nach Masse
5162 - Dieselpartikelfilter Differenzdruckgeber
          P2453 00 [096] - unplausibles Signal
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 3
                    Datum: 2018.08.05
                    Zeit: 17:07:00
                    Motordrehzahl: 0.00 /min
                    Normierter Lastwert: 0.0 %
                    Fahrzeuggeschwindigkeit: 0 km/h
                    Kühlmitteltemperatur: 60 °C
                    Ansauglufttemperatur: 34 °C
                    Spannung Klemme 30: 12.880 V
                    Geber für Differenzdruck über Partikelfilter: Rohwert: 62 hPa
                    Partikelfilter: Differenzdruck: 65 hPa
                    Partikelfilter: Offset für Differenzdruck: -3 hPa
                    Partikelfilter Differenzdruck dynamischer Offset: 0 hPa
                    Außentemperatur: 25.0 °C
                    Partikelfilter: Rußmasse gemessen: 59.49 g
                    Partikelfilter: Rußmasse berechnet: 18.67 g
5189 - Partikelfilter Bank 1
          P2002 00 [096] - Fehlfunktion
                    Fehlerpriorität: 2
                    Fehlerhäufigkeit: 3
                    Datum: 2018.08.05
                    Zeit: 17:05:54
                    Außentemperatur: 24.3 °C
                    Partikelfilter: Rußmasse gemessen: 34.07 g
                    Partikelfilter: Rußmasse berechnet: 19.04 g
                    Partikelfilter: Kilometer seit letzter Regeneration: 140491 m
                    Partikelfilter Feldregeneration: Abbruchbedingungen-Bits 0-7: 0
Readiness: 0 0 0 0 0
Thank you in advance.
Best regards, Patrick.
LOG-01-IDE00427_&9.CSV
 File name:  LOG-01-IDE00427_&9.CSV
 File size:  2.64 KB
 Downloaded:  558 times
Translated on 31-08-2026, 12:39.
Post06-08-2018, 21:13    Subject: Particulate Filter Failure: Causes & Solutions Quote
Repair defects and https://community.dieselschrauber.org/en/viewtopic.php?t=29120 accordingly.
Translated on 31-08-2026, 12:42.
StyLeZP
Post07-08-2018, 20:15    Subject: Particulate Filter Failure: Causes & Solutions Quote
dieselschrauber wrote:
Repair defects
"Thank you, but that's exactly the question: what could likely be defective based on the measured values? I can already imagine that if I go to the dealership, I'll just get a response like, 'The DPF needs to be replaced.'"
I just completed another test run and didn't receive a single error (duration approximately 50 minutes).
I was even able to initiate a forced regeneration while stationary. Overall, everything is fine now. I'm currently unsure about the next steps.
If it happens again or if I gain new insights, I will get back to you.
PS: Of course, I had already read the linked post beforehand.
Translated on 31-08-2026, 12:43.
dieselschrauber and Rüdi likes this.
Post07-08-2018, 21:40    Subject: Particulate Filter Failure: Causes & Solutions Quote
Okay, I'm seeing an error code from the differential pressure sensor. This error may have caused other errors. I need to check, test, and it's likely that the sensor will need to be replaced.
That wouldn't be entirely unreasonable...
Translated on 31-08-2026, 12:44.
Marco_Gorski
Post08-09-2018, 21:51    Subject: Particulate Filter Failure: Causes & Solutions Quote
5268 - Sensor 1 for exhaust gas temperature (G235).
P0545 00 [032] - Short circuit to ground.
Sporadically - unconfirmed - checked since last deletion.
I would start by replacing the sensor, clearing the entries, and then performing a service regeneration.
Translated on 31-08-2026, 12:45.
Post09-09-2018, 9:45    Subject: Particulate Filter Failure: Causes & Solutions Quote
Repair defects
Okay, but that's exactly the question: what could likely be defective based on the measured values? I can already imagine that if I go to the dealership, I'll just get a response like "The DPF needs to be replaced."
It's clearly stated in the Autoscan what's broken, so why aren't the corresponding things being checked? icon_rolleyes.gif
Translated on 31-08-2026, 12:46.
No new posts Adblue System Malfunction – No Error Code or 28653 / P204F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Particulate Filter (DPF) VAG TDI Diesel Mass Balance, Max... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Forced DPF Regeneration: VAG TDI with VCDS Troubleshooting & Guides
No new posts DPF: 2.7/3.0 TDI Diesel Particulate Filter On-Board Diagnostics (OBD)
No new posts New particulate filter Diesel Engine Technology
No new posts Problems with the particulate filter Diesel Engine Technology
No new posts Particulate Filter: Additive-Free & Efficient Diesel Engine Technology
