A4 2.0 TDI Oil Line Removal: BPW Guide
wildfire1
Post24-11-2018, 17:58    Subject: A4 2.0 TDI Oil Line Removal: BPW Guide Quote
Good evening, forum. I need some help.
How can I detach the oil pipe/oil feed line that's already disconnected from the turbo? It seems to be stuck somewhere in the middle, between the engine and the firewall. I haven't been able to find a relevant post about this.
Thank you very much.
Translated on 25-08-2026, 18:24.
wildfire1
Post24-11-2018, 20:43    Subject: A4 2.0 TDI Oil Line Removal: BPW Guide Quote
I found the connection in the middle of the line, but I can't disconnect it, no matter which direction I try icon_sad.gif.
Translated on 25-08-2026, 18:25.
Post25-11-2018, 11:03    Subject: A4 2.0 TDI Oil Line Removal: BPW Guide Quote
wildfire1 wrote:
I found the connection in the middle of the line, but I can't disconnect it, no matter which direction icon_sad.gif
If the cable is loose and is going to be replaced anyway, why don't you just cut it?
Once you have them outside, you might be able to determine, based on their shape, why they got stuck in certain places.
wildfire1
dieselschrauber and Erbse78 likes this.
Post25-11-2018, 11:59    Subject: A4 2.0 TDI Oil Line Removal: BPW Guide Quote
Yes, I had thought about that too, but I wanted to figure out how to get the new one in.
"Thank you for the response, anyway. I've just managed to get the cable connected again. I had to pull it out on the driver's side and thread it back in on the passenger's side... it's definitely a very tedious process, as is tightening the brackets and connectors."
On the turbocharger side, I modified an open-end wrench so that you can hold the fitting in place. Because I didn't have it when loosening it, the oil line broke off icon_sad.gif.
Translated on 25-08-2026, 18:27.
No new posts Removing and cleaning a diesel particulate filter (DPF) Troubleshooting & Guides
No new posts Passat 3BG AVB - Remove bearing from Visco fan Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Remove ESP? Troubleshooting & Installation Guide Diesel Engine Technology
No new posts Removing fuel injectors Diesel Engine Technology
No new posts A4 8E Oil Pan Removal: Guide & Instructions Diesel Engine Technology
No new posts Remove Sun Visors 3C Transmission, Chassis, Body & Interior
