Audi A3 8P Heated Mirrors - Replacement & Repair
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post26-11-2018, 19:49    Subject: Audi A3 8P Heated Mirrors - Replacement & Repair Quote
Hello everyone,
I happened to be looking at the measurement data for the mirror heating system today, and I was surprised:
Contrary to my previous belief, I cannot freely turn the heated mirror on and off using the mirror adjustment knob. The following function is available:
- Activation only occurs when the engine is running; the ignition alone is not sufficient.
- When I set the mirror switch to the heating symbol,
beide Spiegel zunächst dauerbestromt. After approximately 1 minute.
(Outdoor temperature: 5°C) The mirror heater starts to cycle on and off.
The measured value oscillates between active and inactive states.
- The heating system remains, after being initially flushed through the.
Spiegelschalter aktiviert wurde, eingeschaltet. Even though...
The switch will be reset until the next ignition cycle.
The last point is a bit annoying. Is there a way to adjust the settings so that the mirrors can be turned off again using the rotary switch?
Brezelmann.
Translated on 28-08-2026, 3:36.
brezelmann01 likes this.
Post26-11-2018, 20:42    Subject: Audi A3 8P Heated Mirrors - Replacement & Repair Quote
The last point is a bit annoying. Is there a way to adjust it so that the mirrors can be turned off again using the rotary switch?
unknown to me... if the background of your question is the durability of the heating film: it can be easily and cheaply repaired.
/viewtopic.php?t=27654&highlight=heating film
However, the repair only makes sense for dimmable mirrors, as a new, non-dimmable glass costs less than a case of beer. icon_idea.gif
Translated on 28-08-2026, 3:39.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi APS Coding: How To & Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjust Right Side Mirror (Folding/Lowering) Transmission, Chassis, Body & Interior
No new posts Polo Mirror: Left Side, After 2000 Transmission, Chassis, Body & Interior
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi A3 8P 3.2 Gasoline Engine Technology
