Number of LC starts and general DSG transmission check
alevuz
Karma: +32 / -0   Thank you, like it!
Post01-04-2017, 10:50    Subject: Number of LC starts and general DSG transmission check Quote
Since I'm planning to change my car soon and might want to buy something "more powerful" (like a Golf R, S3, RS3, or RS Q3), I'm generally wondering if it's possible to determine the number of LC (presumably "Launch Control") starts a car has had.
This type of vehicle is actually perfectly suited for such operations.
What else can be quickly checked using VCDS in the case of a DSG transmission?
Thank you for your responses.
Alevuz.
Touareg V10 TDI (AYH)
nook
dieselschrauber likes this.
Post24-01-2019, 23:15    Subject: Number of LC starts and general DSG transmission check Quote
Hello, with the DQ500, it is possible to read the number of LC starts.
Go to the transmission control unit, then under "advanced parameters," and you'll be able to search for "launch" and find it there!
No new posts Battery Care: Tips for Checking and Maintenance Technical Articles
No new posts Document LT 28, Transmission Noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts VCDS: Number of Applications On-Board Diagnostics (OBD)
No new posts [Poll] Turbocharger Check: Diagnose & Test On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. VAG Diagnostic Tools: PDAs, On-Board Computers, VCDS On-Board Diagnostics (OBD)
No new posts Vag-Check: Replacing Analog LDA? Diesel Engine Technology
