A4 B6: Acceleration Noises, Driveshaft?
MrMcFly79
Post13-03-2019, 13:01    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
Hello everyone,
I drive a 2004 A4 B6 2.5 TDI 180 hp quattro.
Now, regarding my problem:
"When I accelerate between 1600 and 2000 RPM, I hear a kind of grinding noise from the rear. This only happens when I'm increasing power; it doesn't occur with the standard power output. I've been told it might be the Hardy disc, but others say there isn't one."
Can someone enlighten me?
Tobi.
Translated on 15-10-2026, 17:00.
Karma: +645 / -0   Thank you, like it!
Post13-03-2019, 13:24    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
The rear differential might be worn out; I remember seeing that issue back in my Type 85 days.
Translated on 15-10-2026, 17:01.
MrMcFly79
Post13-03-2019, 15:15    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
That would be absolutely fantastic icon_sad.gif, and does that Hardy disc exist?
Mpire
Avatar-Mpire
2019 Skoda Octavia
dieselschrauber likes this.
Post13-03-2019, 18:01    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
MrMcFly79 wrote:
That would be absolutely fantastic icon_sad.gif and does that Hardy disc exist?
No.
The constant velocity joint (CV joint) has two universal joints.
I would recommend checking the oil levels and the condition of the oil in the center differential and the rear axle, and also looking for any signs of wear particles in the oil, as these could indicate wear on the bearings or gears.
Mpire
Translated on 15-10-2026, 17:02.
MrMcFly79
Post13-03-2019, 20:18    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
We changed the oil a few months ago, and I didn't really pay close attention to the condition of the oil, but it looked honey-colored icon_wink.gif.
Karma: +591 / -0   Thank you, like it!
Post13-03-2019, 20:55    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
Hi!
From old times, from the BMWs of my friends...
I'm familiar with problems related to the bearing.
Specifically, there was an intermediate bearing on the body, within the tunnel where the driveshaft passes, and this bearing was generously housed in a type of rubber boot.
If the rubber was worn out, or the bearing inside it, the drive would also make a rumbling noise under load.
I don't know how much of that applies to your car.
But please check if there's a storage facility there.
Translated on 15-10-2026, 17:03.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post13-03-2019, 21:18    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
Hi there,
Cardan intermediate support is a good idea icon_smile_thumb_up.gif.
"Unfortunately, there's no individual part available, only the complete driveshaft."
The intermediate bearing with bracket is available as an accessory and is the same for all engine types in the B6 and B7 models.
Search for "8E0521101B" on eBay.
This part number is listed in the central warehouse, but it's not available at the Audi parts counter.
Mpire
Translated on 15-10-2026, 17:04.
MrMcFly79
Post14-03-2019, 10:24    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
Super, danke für die Tips. I'll check that out.
Tobi.
Translated on 15-10-2026, 17:05.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
dieselschrauber and Mpire likes this.
Post14-03-2019, 20:51    Subject: A4 B6: Acceleration Noises, Driveshaft? Quote
If you need to replace the central bearing, it is crucial to ensure the correct assembly of the joints. It is best to mark the original position beforehand with a punch mark.
Translated on 15-10-2026, 17:06.
No new posts Acceleration Ends Before Max Speed General Tips
No new posts TDI Wave Acceleration: Causes and Solutions Technical Articles
No new posts Document: A4, Emergency Procedure After Strong Acceleration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Renault Kangoo 4x4 Driveshaft Transmission, Chassis, Body & Interior
No new posts Is this true for Audi quattro? Transmission, Chassis, Body & Interior
No new posts A4 2.5 V6 TDI: Loud Exhaust Sound (B5 Quattro) Diesel Engine Technology
No new posts Automatic shift timing programming for Audi A6 quattro On-Board Diagnostics (OBD)
