Air Suspension Control Unit Replacement
fordi
Karma: +0 / -1   Thank you, like it!
Post28-03-2019, 18:19    Subject: Air Suspension Control Unit Replacement Quote
Hello, I'm having a problem with an Audi Q7.
I replaced the control unit and performed the basic calibration.
After starting, I received the following error: 00149 No end-of-tape programming has been performed.
005 No initial setup or incorrect adaptation.
Error status: 11100101
Environmental conditions: 140.
I took the code from the old control unit.
Translated on 08-10-2026, 12:40.
Back to top Profile PM Email
Post28-03-2019, 18:49    Subject: Air Suspension Control Unit Replacement Quote
Error 00149 No band termination programming has been performed.
The control unit was not programmed to the desired state after manufacturing. icon_idea.gif
Where did you get the control unit from?
Translated on 08-10-2026, 12:41.
fordi
Post29-03-2019, 7:32    Subject: ECU: Steuergerät - Definition und Funktion Quote
Directly purchased from Audi.
vag-driver
Post29-03-2019, 10:55    Subject: Air Suspension Control Unit Replacement Quote
Then I would return the faulty device to the store with the error message and take a new one.
Andreas
Translated on 08-10-2026, 12:42.
fordi
Post29-03-2019, 12:56    Subject: ECU: Steuergerät - Diagnose und Reparatur Quote
Okay, thanks, I spoke with Audi, and they are programming it.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air suspension Transmission, Chassis, Body & Interior
No new posts Audi A8 air suspension basic settings Transmission, Chassis, Body & Interior
No new posts 1.9 PD ASC Replacement Diesel Engine Technology
No new posts Turbocharger Replacement: Buy Now! Diesel Engine Technology
