AHK Retrofit Programming: Guide & Tutorial
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
luebby
Karma: +0 / -1   Thank you, like it!
Post13-05-2019, 8:06    Subject: AHK Retrofit Programming: Guide & Tutorial Quote
Hello, I'm having a problem with the retrofit installation.
I have a Skoda Superb 3V, manufactured in MJ2018, and I retrofitted the original tow hitch.
Since the control unit was installed, the car has been throwing various error codes.
ACC is not working, for example, because it indicates that the control unit is incorrectly programmed (which is actually true).
Then I tried to program according to that guide.
Steps for retrofitting the tow hitch:
- In the CAN gateway, using the coding function and address 19, code the "trailer control unit." The VCDS coding assistant (tooltip or LCode) will guide you through the process.
- If a PDC (Parking Distance Control) system is installed (address 76), enter the extension length of the rear parking sensor in channel 2 by making an adjustment.
- If the parking assist system is installed (address 10), adjust the coding. The VCDS coding assistant (tooltip or LCode) will tell you how.
- ABS/ESP control unit (address 03), enable trailer stabilization if supported.
- Body control module (address 09), activate the function to disable the rear fog light when a trailer is connected. The coding assistant (tooltip or LCode) in VCDS will tell you how.
- Engine control unit (address 01), reprogram to enable trailer hitch (standard or extended programming, depending on the control unit). Ignition must be ON, engine must be OFF. Unlike older control units, no login code is required; instead, it is directly programmed.
- If a reverse camera (address 6C) is installed, also check and adjust its settings through the coding.
However, I was only able to specify the new control unit in the gateway, which worked (and since then, the error has disappeared, as the new control unit is now recognized).
However, in all the other control units mentioned above, VCDS did not offer an option to configure a trailer hitch. So, I guess I'll have to do it the old-fashioned way, by manually coding it in binary.
Now, of course, I don't know how many bits I'm allowed to add or subtract in which control unit.
I found something here for an A4 from 2015 where it was installed in the ACC icon_smile_thumb_up.gif for trailer hitch (AHK) and +8 for not installed. Does that also apply to the Superb? Then I would only have to subtract 7 bits, but I'm not brave enough to try that *g*.
And what about the bits for engine control, parking distance control, ABS/stability control, and the vehicle's electrical system?
Here's the scan. I'm not concerned about the other errors for now; they're not related to the AHK. The errors specifically related to the AHK are only in the engine control unit and the ACC/distance control system.
VCDS -- A VAG/VAS emulator based on Windows, runs on Windows 10 x64.
VCDS Version: DRV 18.9.1.0
Data as of: 20190215 DS296.0
www.Ross-Tech.de
Vehicle Identification Number: TMBJB7NP2J759. License plate:
Mileage: 18405 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 47 4B 52
5F 69 6C 6D 75 A5 BB BC
Mileage: 18,405 km
01-Motor electronics -- Status: Error 0010.
02-Gearbox -- Status: OK 0000
03-Brake electronics -- Status: Error 0010.
05-Access/Startup Report -- Status: OK 0000
08-Climate Control/Heating Unit -- Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
Parking Assist 10 -- Status: OK 0000
13-meter distance rule -- Status: Error 0010.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: Error 0010.
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
2B steering column lock. -- Status: OK 0000
36-seat adjustable passenger seat -- Status: OK 0000.
3C Lane Change -- Status: OK 0000
42-Volt electric vehicle driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B Multifunction Device -- Status: INTERFACE HARDWARE NOT COMPATIBLE.
52-inch electric auxiliary passenger seat -- Status: OK 0000
5F-Information Selection. I -- Status: OK 0000
69-pin connector -- Status: Error 0010.
6C Rear-view camera -- Status: OK 0000
6D tailgate -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5 Front/Forward-facing camera -- Status: Error 0010.
Rear left side blind spot monitoring system -- Status: OK 0000.
Rear right side door electronics -- Status: OK 0000.
Address 01: Engine Control Module (J623-CZEA)
Label file: .DRV\04E-907-309-V1.clb
Part number SW: 04E 906 027 BT, Hardware number: 04E 907 309 AB.
Part: R4 1.4l TFS H24 9177
Revision: R9H24---
Encoding: 01250072246405087000
Operating number: WSC 33361 790 00138
ASAM Dataset: EV_ECM14TFS01104E906027BT 001011
ROD: EV_ECM14TFS01104E906027BT.rod
VCID: 77F666BBCEB48BF2EC-8022
Control unit, center console, 1:
"One error found:"
17156 - Received error value on the data bus.
U1123 00 [047] - -
confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 6.
Error frequency: 10
Mileage: 18334 km
Date: 2019.05.10
Time: 20:45:48
Motor speed: 0.00 rpm.
Normalized load value: 0.0%
Vehicle speed: 0 km/h
Coolant temperature: 23 °C
Intake air temperature: 24 °C
Ambient air pressure: 1010 mbar.
Voltage at terminal 30: 12.038 V.
Lost mileage counter via OBD: 40.
Acceleration: 0.000 m/sÂČ or less.
Speed control system: Status bits 0-7: 6.
Powertrain Coordinator: ACC fault status bits 0-7: 0.
Powertrain Coordinator: Shutdown reasons in GRA and ACC operation - Bits 0-7: 0.
Powertrain Coordinator: Brake error status bits 0-7: 0.
Accelerator pedal position: 0.00%
Readiness: 0000 0000
Address 02: Transmission (J743)
Label file: DRV\0CW-927-769.clb
Part number SW: 0CW 300 041 Q, HW: 0AM 927 769 E.
Component: GSG DQ200G2_M H05 1605
Revision: 00005008 Serial number: CU501804215835
Encoding: 0014
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021_VW31.rod
VCID: 438EC26BCAEC175280-8016
No error codes found.
Address 03: Brake Electronics (J104)
Label file: 5Q0-907-379-IPB-V1.clb
Part number SW: 5Q0 614 517 DA, HW: 5Q0 614 517 AH.
Component: ESC H62 0753
Revision: 00000000 Serial Number: 61298000001565
Encoding: 1E076A9C342923734778060960C34978562CC4E2600692753821F078C2A2420B00000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
VCID: 73EE52ABDACCE7D2D0-8026
"One error found:"
16401 - Tire pressure warning.
C102D 00 [008] - -
Sporadically - confirmed - checked since last deletion.
Error priority: 2
Error frequency: 6
Lost Count: 175
Mileage: 9623 km
Date: 2018.11.06
Time: 09:47:17
Address 05: Access/Start Authorization (J518)
Label file: | DRV\5Q0-959-435.clb
Part number SW: 3Q0 959 435 G, HW: 3Q0 959 435 G.
Part number: VWKESSYMQB 037 0907
Revision: 00037000 Serial Number: 0479642302
Encoding: 032C0C070F
ASAM Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB_004_VW37.rod
VCID: 3E78B39FA10E7ABAEF-806A
Control unit for tailgate opening.
Subsystem 1 - Part number SW: 3AA 962 243 G, HW: 3AA 962 243 G.
Component: GEB.F.Heckoef H16 0903
Serial number: 84564150
Address 08: Climate Control/Heating (E87)
Label file: | 3V0-907-044.clb
Part number SW: 3V0 907 044 CP, HW: 3V0 907 044 CP.
Component: AC Automatic Transfer Switch, Model H34 4402.
Revision: 20K10000 Serial Number: 00000B00944945
Encoding: 12010004000410011005100D0010112A
Operating number: WSC 33361 790 00165
ASAM Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X_SK37.rod
VCID: 040C01778F62D06AF9-8050
Humidity sensor: outdoor:
Rear climate control panel:
Subsystem 2 - Part number SW: 3V0 907 049 E, HW: 3V0 907 049 E.
Part: E265 Climate Rear Panel H02 0101.
Serial number: 06051501850797
Encoding: 000000
2 error codes found:
655628 - Functionality restriction due to power management.
B10CD 00 [008] - -
[New Feature! Extended UDS error code information is supported only by the current generation of hardware.]
Error priority: 7
Error frequency: 4
Lost Count: 170
Mileage: 17686 km
Date: 2019.04.24
Time: 14:20:49
328452 - Temperature flap control motor, rear.
B108E 71 [008] - Actuator jammed.
Error priority: 2
Error frequency: 2
Lost Count: 158
Mileage: 16847 km
Date: 2019.04.09
Time: 10:37:01
Voltage at terminal 30: 14.8 V.
Indoor temperature: 24.2 °C
Outdoor temperature: 8.0 °C
Rear temperature flap - Current value: 102.
Rear temperature control valve - Actual value: 0.5 %.
Rear temperature control valve - Target value: 89.
Address 09: Central Electronics (J519)
Label file: .DRV\5Q0-937-08X-V2.clb
Part number SW: 5Q0 937 084 CQ
Part number HW: 5Q0 937 084 CG
Component: BCM MQBAB H H36 0253
Serial number: 01001812500385
Encoding: 0000000000000000000000000000000
ASAM Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 09121043A8408D028A-805C
Control unit for wiper motor:
Subsystem 1 - Part number SW: 3V1 955 119 HW: 3V1 955 119 Label file: DRV\5QX-955-119-V1.CLB
Component: 48x LL 180418 032 0121
Serial number: 00000001804130302745
Encoding: 164DDD
Rain and light sensor:
Subsystem 2 - Part number SW: 5Q0 955 547 B HW: 5Q0 955 547 B Label file: DRV\5Q0-955-547.CLB
Component: RLHS 050 0107
Serial number: SAY18M05D08H17M32S48
Encoding: 0088DF
LĂŒfter 1 for front left seat backrest:
Subsystem 3 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Component: SysNameFanLin 014 0101.
Serial number: ESE0884390
LĂŒfter 1 for front left seat cushion:
Subsystem 4 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Serial number: ESE0391582
LĂŒfter 1 for front right seat backrest:
Subsystem 5 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Serial number: ESE0878274
LĂŒfter 1 for front right seat cushion:
Subsystem 6 - Part number SW: 3G0 963 345, HW: 3G0 963 345.
Serial number: ESE0391577
"One error found:"
204290 - Radio key 1.
B1479 18 [009] - Current too high.
Error priority: 4
Error frequency: 1.
Lost Count: 154
Mileage: 18,366 km
Date: 2019.05.11
Time: 11:39:22
Address 10: Parking Assist 2 (J791) Label file: | DRV\5Q0-919-298.clb
Part number SW: 5QA 919 298 C, HW: 5QA 919 298 A.
Component: PLA 3.0 12KH07 0045
Serial number: 000308417618132
Encoding: 0271167851
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 50A4FD270B9AFCCA0D-8004
Address 13: Distance Control (J428)
Label file: 3Q0-907-572.clb
Part number SW: 3Q0 907 572 C. Hardware: 3Q0 907 572 C.
Part number: ACC BOSCH MQB H04 0195.
Encoding: 320067C355FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 356AACB39438B9E23E-8060
"One error found:"
1229 - Control unit incorrectly coded.
U1014 00 [009] - -
Error priority: 4
Error frequency: 1.
Lost Count: 150
Mileage: 18265 km
Date: 2019.05.09
Time: 17:18:49
Engine control unit temperature: 21 °C.
Voltage at terminal 15: 11.6 V.
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/sÂČ (or less)
Status_ACC_System: ACC_StandBy
Address 15: Airbag (J234) Label file: | DRV\5Q0-959-655.clb
Part number SW: 5Q0 959 655 BH, Hardware number: 5Q0 959 655 BH.
Part: Airbag VW21 005 0336
Serial number: 003VVR45YKP8
Encoding: 98CCC0C0000000005C5400CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0716167BBE54FB729C-8052
Crash sensor for driver-side side airbag:
Subsystem 1 - Part number: SW: ----------- HW: 480 000 205 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000B3B644C2P
Encoding: 2D2D2D
Crash sensor for the passenger-side front airbag.
Subsystem 2 - Part number: SW: ----------- HW: 480 000 205 18
Component: SideSensor_Pf 001 0887
Serial number: 358000000009346D4E2S
Encoding: 2D2D2D
Crash sensor for rear side airbag, driver's side.
Subsystem 3 - Part number: SW: ----------- HW: 480 400 405 18
Component: SideSensor_Dr 000 6149
Serial number: 3510001B329E65D221D5
Encoding: 2D2D2D
Crash sensor for rear side airbag, passenger side.
Subsystem 4 - Part number: SW: ----------- HW: 480 400 505 18
Component: SideSensor_Pr 000 6149
Serial number: 3520001C929E65D2B71G
Encoding: 2D2D2D
Crash sensor for front airbag, driver side:
Subsystem 5 - Part number: SW: ----------- HW: 480 402 804 18
Component: FrontSensor_D 000 6149
Serial number: 355000199298DB43D2AL
Encoding: 2D2D2D
Address 16: Steering wheel electronics (J524)
Label file: | DRV\5Q0-953-549.clb
Part number SW: 5Q0 953 521 LA, HW: 5Q0 953 569 B.
Component: Steering module 100 0245.
Revision: FF036036 Serial number: 20180514500661
Encoding: 6414
ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7CFC7997F792A8AA81-8028
"One error found:"
291104 - Temperature sensor for steering wheel heating.
B1455 01 [008] - Electrical fault.
Error priority: 2
Error frequency: 254
Lost Count: 194
Mileage: 7 km
Date: 2018.07.04
Time: 10:51:42
Ubat 30 Voltage: 12.50 V
Internal error state: 0
LIN_Temp: 0
Isense: 0
Maximum power: 110.
PWM: 0
Offset: 0
Slope: 134
kp: 18
out: 50
Temperature (Static): 30.
p_t_soll_0: 34.00 °C
p_t_soll_1: 39.00 °C
p_t_soll_2: 44.00 °C
Address 17: Control panel module (J285)
Label file: | DRV\5G0-920-XXX-17.clb-SRI3
Part number SW: 3V0 920 750 B HW: 3V0 920 750 B
Component: COMBINATION UNIT 301 0310
Encoding: 07A5091A6F84000801886B0B5001000800000000
Operating number: WSC 73430 031 00138
ASAM Dataset: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 326097AF6556AEDA1B-8066
Address 19: Diagnostic Interface (J533)
Label file: | DRV\3Q0-907-530-V1.clb
Part number SW: 3Q0 907 530 L, HW: 3Q0 907 530 C.
Part: GW MQB High, 518 5323.
Serial number: 03051810802928
Encoding: 0B0100047F085708EB00025A1C0F00010001070000000000000000000000
Operating number: WSC 33361 790 00160
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3874A587832A448A25-806C
Generator:
Control unit for multifunction steering wheel:
Subsystem 2 - Part number SW: 3V0 919 719 D, HW: 3V0 919 719 D.
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000D2638030518
Battery monitoring control unit:
Subsystem 3 - Part number SW: 5Q0 915 181 K, HW: 5Q0 915 181 K.
Part: J367-BDM Hella H10 9070
Serial number: 4195827204
Power inverters for wall outlets:
Subsystem 4 - Part number SW: 5Q0 907 155 B, HW: 5Q0 907 155 B.
Component: U13DCAC H25 0780
Serial number: 0107614
Address 2B: Steering column lock. (J764)
Label file: *DRV\5Q0-905-861.clb
Part number SW: 3Q0 905 861 B, Hardware: 3Q0 905 861 B.
Component: ELV-MQBB H05 0020
Serial number: 18000150747003
Encoding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 336E92AB9A4CA7D210-8066
Address 36: Seat adjustment for driver (J810) Label file: * None
Part number SW: 5Q0 959 760 C. Hardware: 5Q0 959 760 C.
Component: Seat Memory H09 0024
Serial number: Y0006RE134708.
Encoding: 0010000000000500018280808080000000008181000000D400
ASAM Dataset: EV_SeatMemorDriveSide 002022
ROD: EV_SeatMemorDriveSide.rod
VCID: 3D7AB493AC0861A2F6-8068
Address 3C: Lane Change (J1086)
Label file: | DRV\5Q0-907-686.clb
Part number SW: 5Q0 907 686 C. Hardware: 5Q0 907 686 C.
Component: HRE_Master H12 0081
Serial number: 0479413446
Encoding: 02011103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
Control unit 2 for lane change assist.
Subsystem 1 - Part number SW: 5Q0 907 685 C, HW: 5Q0 907 685 C.
Component: HRE_Slave H12 0081
Serial number: 0479692885
Encoding: 020111
Address 42: Turntable Driver (J386) Label file: | 5QX-959-X93-42.clb
Part number SW: 5Q4 959 593 E, HW: 5Q4 959 593 B.
Component: TSG FS 011 0032
Serial number: 0000320098506
Encoding: 001D8920DE00040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 4796D67BFED43B725C-8012
Address 44: Steering Assist (J500)
Label file: * None
Part number SW: 5Q0 910 143 C, HW: 5Q0 910 143.
Component: MQB_VWBS_GEN2 212 2211
Serial number: 820030 00.
Encoding: 0101001100400110
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_SK37.rod
VCID: 2B5E8ACB427CFF1258-807E
Address 47: Soundsystem (J525) Label file: | DRV\81A-035-466.clb
Part number SW: 81A 035 223 Hardware number: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial Number: SKZ8Z1JJE04JD77
Encoding: 0384020000AA002FAA000000000000
ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 59B200035860BD82FA-800C
Address 4B: Multifunction device.
Interface hardware is not compatible.
Please purchase a current Ross-Tech diagnostic interface.
Address 52: Door electrical fitting, passenger side (J387) Label file: | 5QX-959-X92-52.clb
Part number SW: 5Q4 959 592 E, HW: 5Q4 959 592 B.
Component: TSG BFS 011 0032
Serial number: 0000320835875
Encoding: 001D0320DE00040000001100
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 4688DB7FF9DE227AA7-8012
Address 5F: Information selection. I (J794)
Label file: | 3V0-035-MIB-HGH2.clb
Part number SW: 565 035 021 B. Hardware number: 565 035 021.
Component: MU-H-LND-EU H54 1240
Serial number: A853E0JS049411
Encoding: 03840201000000004111120200880A332F0100E4012005009E
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 0D1A2453DC289122A6-8058
Display and control unit 1 for information electronics:
Subsystem 1 - Part number SW: 3V0 919 606 D, HW: 3V0 919 606 D.
Component: ABT_High-2 H50 9130
Serial number: SKZ6ZHV1293815
Data carriers:
Subsystem 2 - Part number SW: V03 959 801 JR HW: -----------
Component: ECE 2019 --- 0175
Serial number: --------------------
Compact Disc Database:
Subsystem 3 - Part number SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1017
Address 69: Trailer (J345) Label file: | DRV\5Q0-907-383.clb
Part number SW: 5Q0 907 383 N. Hardware number: 5Q0 907 383 N.
Component: Trailer H27 0264
Revision: 8A001003 Serial number: 0465117918
Encoding: 0100000202000000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 4280C76FD5F61E5A8B-8016
3 error codes found:
136194 - Supply voltage.
U1011 00 [008] - Voltage too low.
Error priority: 3
Error frequency: 1.
Lost Count: 194
Mileage: 18405 km
Date: 2019.05.11
Time: 13:44:55
136203 - Power supply.
P1757 00 [009] - Interruption.
Error priority: 3
Error frequency: 1.
Lost Count: 153
Mileage: 18334 km
Date: 2019.05.10
Time: 21:10:09
711179 - Contact switch on the locking bolt.
C10E7 13 [009] - Interruption.
Error priority: 3
Error frequency: 1.
Lost Count: 153
Mileage: 18334 km
Date: 2019.05.10
Time: 21:10:07
Address 6C: Reverse camera (J772)
Label file: | DRV\5Q0-980-556.clb
Part number SW: 5Q0 980 556 B, HW: 5Q0 980 556 B.
Component: RVC Compact, H12 0231.
Encoding: 04840201A600201F000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
VCID: 3972A083B8205D82DA-806C
Address 6D: Rear door (J605)
Label file: | DRV\5Q0-959-107.clb
Part number SW: 5Q0 959 107 P, HW: 5Q0 959 107 J.
Component: HDSG Module H13 0266
Revision: -------- Serial Number: 31934193800000
Encoding: 0D08
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 458ADC73C4D82962AE-8010
Address 75: Telematics (J949) Label file: | 5QE-035-285.clb
Part number SW: 5NA 035 284 B. Hardware number: 5NA 035 284 B.
Component: OCULowMQBLGE H17 0718
Revision: --------
Encoding: 03840201EA421A0D3B1C9E000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW41.rod
VCID: 3C7CB997B71268AAC1-8068
Address A5: Front/Forefield Camera (R242)
Label file: | DRV\3Q0-980-65X-A5.clb
Part number SW: 3QD 980 654. Part number HW: 3Q0 980 654 A.
Component: MQB_B_MFK H08 1272
Serial number: 12031841K11299.
Encoding: 020408020000040100262354C150A90098000E100040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
VCID: 08141547B34AF40A95-805C
1123187 - Local data bus.
U116B 00 [009] - Received error value.
Error priority: 6.
Error frequency: 18
Lost Count: 154
Mileage: 18265 km
Date: 2019.05.09
Time: 17:18:50
Engine control unit temperature: 14 °C.
Outdoor temperature: 15.5 °C
Vehicle speed: 0.00 km/h
System runtime: 3.3 s
Voltage at terminal 15: 11.5 V.
mid: 02 C0
Camera status: ready.
Engine_Running_Info: 0
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 1
1275 - Unknown error code.
B182E F0 [008] - Unknown error description.
Error priority: 4
Error frequency: 1.
Lost Count: 14
Mileage: 3142 km
Date: 2018.08.09
Time: 11:35:26
Engine control unit temperature: 42 °C.
Outdoor temperature: 19.5 °C
Vehicle speed: 9.22 km/h
System runtime: 5088.7 s
Voltage at terminal 15: 12.7 V.
mid: 01 63
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 1
Address BB: Rear left tail light (J388)
Label file: * None
Part number SW: 5Q4 959 595 E. Part number HW: 5Q4 959 595 B.
Component: TSG HFS 012 0032
Serial number: 0000319505846
Encoding: 001881208000040000001100
ASAM Dataset: EV_DCURearDriveMAXCONT 006001
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 4992D043E8C0CD024A-801C
Address BC: Rear right side electronic component (J389)
Label file: * None
Part number SW: 5Q4 959 595 E, HW: 5Q4 959 595 B.
Component: TSG HBFS 012 0032
Serial number: 0000319509487
ASAM Dataset: EV_DCURearPasseMAXCONT 006001
ROD: EV_DCURearPasseMAXCONT.rod
End----------------------------(Duration: 06:26)-----------------------------
Translated on 11-09-2026, 11:39.
Post13-05-2019, 16:43    Subject: AHK Retrofit Programming: Guide & Tutorial Quote
I found something here for an A4 from 2015, where it was configured in the ACC icon_smile_thumb_up.gif for AHK, and +8 for not installed.
Does that also apply to the Superb? If so, I would only need to subtract 7 bits, but I'm not brave enough to try that *g*. }
Is the pre-scan of the vehicle saved so that you have the original coding data?
The only thing you've coded so far is the gateway, right?
Then, I would first check if the error messages from the trailer control unit can be cleared.
Because if not, there will be a good reason, and I suspect it's due to incorrect wiring.
Translated on 11-09-2026, 11:40.
luebby
Post13-05-2019, 23:14    Subject: AHK Retrofit Programming: Guide & Tutorial Quote
I only installed and programmed the AHK script on the gateway.
The rest is, of course, still in its original condition.
The wiring shouldn't be wrong, as the car comes with the preparation from the factory, and everything is already pre-wired with connectors. So it's basically plug and play.
The error message "trailer hitch not locked" is correct because I haven't plugged in the connector yet (otherwise, I would have to first put the trailer hitch in the trunk and then connect it).
I wanted to program everything first and see if it runs without any problems, and then add the AHK (AutoHotkey) functionality on top of it.
The engine control unit and the vehicle's electrical system immediately throw the error code again after it's been cleared (which is understandable, since they haven't been programmed yet).
However, I haven't installed any AHK (trailer hitch) options in either of the control units, and I don't know how many bits I'm supposed to subtract or add.
"And since the only information I found here was about an A4 from 2014 that exhibited the exact same issues after being modified, I wanted to ask if this is also the case for a Superb 2018 before I proceed with the modification."
Translated on 11-09-2026, 11:43.
Post19-05-2019, 7:30    Subject: AHK Retrofit Programming: Guide & Tutorial Quote
Hello.
Part number SW: 5Q0 907 383 N, Hardware: 5Q0 907 383 N.
Component: Trailer H27 0264.
[New feature! Extended UDS error code information is supported only by the current hardware generations.]
I think you won't get very far with your old diagnostic system when it comes to these new cars...
Translated on 11-09-2026, 11:46.
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Programming keys Diesel Engine Technology
No new posts Program Daytime Running Lights? On-Board Diagnostics (OBD)
No new posts TT5 Programming for Audi A6 On-Board Diagnostics (OBD)
No new posts Immobilizer 1H0 953 257 B: Reprogramming & Replacement On-Board Diagnostics (OBD)
