ASZ TDI Euro 3: AGR Valve Replacement & Deactivation
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
kiter
2015 Seat Leon
Post03-09-2019, 21:02    Subject: ASZ TDI Euro 3: AGR Valve Replacement & Deactivation Quote
I'm slowly but surely overtaking my 2002 Ibiza with my heavily modified ASZ 130hp 310Nm TDI engine.
I replaced the AGR valve 100,000 kilometers ago.
Now, I want to do something good for the engine and the intake system for the next few years, and that means deactivating the EGR system.
I place the highest value on maximizing the engine's lifespan.
Deactivating the EGR system doesn't directly affect the engine itself. However, could the engine experience increased stress in the lower load range due to a higher combustion temperature?
Could I gradually clean the intake manifold over the long term using some kind of chemical treatment?
I would appreciate hearing about your experiences.
Translated on 14-09-2026, 12:00.
dieselschrauber likes this.
Post04-09-2019, 17:02    Subject: ASZ TDI Euro 3: Deactivate EGR for Inspection Quote
kiter wrote:
Now, I want to do something good for the engine and the intake system for the next few years, and that includes deactivating the EGR.
The AGR (Abgasrückführung) significantly contributes to faster engine warm-up under partial load conditions. You will notice this very clearly during the winter.
Longer warm-up times are not beneficial for extending the lifespan.
kiter wrote:
Deactivating the EGR system doesn't actually have a direct impact on the engine.
The engine control unit (ECU) might easily detect that it cannot control the air mass using the AGR valve. However, I don't know if your specific ECU will report this as an error. In the previous generation (1Z/AHU/AFN), no errors were reported. From Euro 4 onwards, errors were definitely reported. I'm unsure about Euro 3.
kiter wrote:
Can it happen that the engine, in the lower load range, experiences overstress due to a higher combustion temperature?
Negligible.
The engine is more likely to experience high combustion temperatures under high load, and in those situations, the EGR system is usually closed anyway.
kiter wrote:
Could I gradually clean the intake manifold over the long term using some kind of chemical?
Time heals all wounds icon_wink.gif.
The airflow and the oil will probably gradually clean it again.
But first, one should check: Is there even a problem? Is everything really clogged?
Here in the forum, you can find several cleaning reports (with and without major disassembly) and corresponding pictures.
I once deactivated the AGR myself in my AHU vehicle. The warm-up time in winter was only acceptable with a pre-heater. Without a pre-heater, I would have removed the AGR system completely after the first winter.
Translated on 14-09-2026, 12:03.
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Euro 5 Diesel: MSG Update reveals cheating? On-Board Diagnostics (OBD)
No new posts Crankcase Ventilation: How to Disable/Deactivate Diesel Engine Technology
This topic is locked, you cannot edit or reply. AGR Ventil (stillegen???) Diesel Engine Technology
No new posts When should I set the AGR? Diesel Engine Technology
