Entsperren der Standheizung Octavia 5E | Posts 16+
Go to page: Previous  1, 2
vag-driver
dieselschrauber likes this.
Post28-05-2018, 10:00    Subject: Quote
harzer1 wrote:
The deletion of the parking heater error codes is being refused.
For security reasons, you will not be able to unlock the STHZ in this state. The error must be resolved first.
BTW: What was repaired or replaced on the STHZ?
Andreas
Translated on 01-09-2026, 8:36.
harzer1
Post29-05-2018, 18:58    Subject: Quote
Hello, I think I'm going in circles.
Only failed start attempts, which are usually caused by long idle times or fuel shortages, are displayed.
The car is practically brand new, so nothing has been repaired or worked on.
There are no errors stored, except for the failed attempts.
Translated on 01-09-2026, 8:37.
Post29-05-2018, 19:41    Subject: Quote
I have removed the duplicate post.
How new is the car?
There are reports of similar cases where exchanges were handled very generously.
Did the error just happen spontaneously?
Translated on 01-09-2026, 8:38.
harzer1
Post30-05-2018, 6:56    Subject: Quote
The car has only 30,000 kilometers on the odometer and is from 2016.
Yes, it just happened like that, after the third attempt to start.
It's perfectly understandable that it locks after three unsuccessful attempts, but if there's no specific error code stored, it should also be possible to unlock it again, for example, when you want to restart the heating system after a repair.
Translated on 01-09-2026, 8:39.
vag-driver
Post30-05-2018, 8:19    Subject: Quote
According to the error log, the errors occurred as early as at 9xyz km. Surely, this should have been noticed during the service.
Furthermore, in the case of fuel shortage, the error log explicitly states "fuel shortage." The cause of the error is definitely located elsewhere.
Andreas
Translated on 01-09-2026, 8:40.
harzer1
Post30-05-2018, 9:58    Subject: Quote
Hello Andreas, thank you for thinking about it and wanting to help me.
Yes, the error message "no flame detected" is a bit vague.
But I think I need to disable the lock to get a more accurate error diagnosis and to have three more attempts to start it.
Rene
Translated on 01-09-2026, 8:41.
vag-driver
Post30-05-2018, 10:33    Subject: Quote
harzer1 wrote:
But I think to get a more accurate error diagnosis, I need to disable the lock to have 3 new startup attempts
This is a chain of security conditions. You will not be able to unlock it if there are such error entries. And that is correct.
You will likely need to take your car to an Audi dealership or a qualified service center that specializes in maintaining and repairing auxiliary heaters.
Is there still a warranty on the vehicle? If it has been serviced at Audi dealerships so far, I would like to raise a complaint about the existing error entry from 9xyz km and ask why I wasn't informed about it.
Andreas
Translated on 01-09-2026, 8:42.
harzer1
Post27-11-2019, 14:12    Subject: Quote
Hi Rainer, maybe you could elaborate on the access permissions again. I just had a case with a standing heater in a T6 where a "too high resistance in the glow plug" error was displayed, and then the heater was locked. After replacing the glow plug, I couldn't clear the error because the heater was still locked, and I couldn't unlock it because I didn't have the necessary access permissions.
Rene
Translated on 01-09-2026, 8:43.
Post29-11-2019, 8:08    Subject: Quote
harzer1 wrote:
Hello Rainer, perhaps you could elaborate on the access permissions again. I just had a case with a standing heater in a T6 where a "too high resistance in the glow plug" error was displayed, and then the heater was locked. After replacing the glow plug, I couldn't clear the error because the heater was still locked, and I couldn't unlock it because I didn't have the necessary access permissions.
Best regards, Rene
Sorry, this is only for customers.
Translated on 01-09-2026, 8:44.
harzer1
Post29-11-2019, 8:20    Subject: Quote
I am a customer.
Translated on 01-09-2026, 8:45.
Post29-11-2019, 13:51    Subject: Quote
harzer1 wrote:
I am a customer
Good that you've synchronized your contact information.
If you log out/log in now, it will still be displayed like this. icon_idea.gif
harzer1
Post29-11-2019, 14:54    Subject: Quote
To add to this, even though I couldn't delete the entries at that moment and the pop-up appeared indicating that I didn't have the necessary access permissions, the heating eventually started working again.
Translated on 01-09-2026, 8:46.
Post29-11-2019, 20:36    Subject: Quote
Thank you for the feedback!
Here's how to unlock the pre-heating function:
No new posts Unlock Vehicle Diagnostic Protection (SFD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Auxiliary Heater Installation: Octavia 1U5 1.9 TDI Transmission, Chassis, Body & Interior
No new posts Log BKD Octavia 2.0 TDI Upload
No new posts Octavia Control Unit: Buy Online Now! On-Board Diagnostics (OBD)
No new posts Octavia 1U 1.8T power fluctuation Gasoline Engine Technology
