Webasto Heater Problems Sharan 7N
vag-driver
Post07-10-2017, 13:19    Subject: Webasto Heater Problems Sharan 7N Quote
Yesterday, I wanted to use the convenience of the auxiliary heater. Unfortunately, this didn't happen without an error message.
Address 18: Auxiliary heater
Label file: DRV\1K0-815-007.clb
Part number: 7N0 963 272 A
Component: Portable heater 043 4730
Revision: 00043000 Serial number: 09022127000000
Encoding: 0031142
Operating number: WSC 00020 790 00000
VCID: 336329C9527ED1DE47-8066
3 error codes found:
01410 - Heater overheating.
000 - -
Environmental conditions:
Error status: 01100000
Error priority: 2
Error frequency: 1.
Lost Count: 65
Time: 0.
Afterglow.
Temperature: 148.0°C
Temperature: -48.0°C
Voltage: 12.07 V
01411 - Temperature sensor (G18)
007 - Short circuit to ground - Intermittent.
Error status: 00100111
Error priority: 3
Error frequency: 3
Lost Count: 105
Mileage: 123792 km
Time: 0.
Date: 2012.02.27
Time: 14:31:01
Disturbance.
Temperature: 205.0°C
Voltage: 12.00 V
02251 - Heating device locked.
000 - -
Error priority: 2
Error frequency: 1.
Lost Count: 65
Time: 0.
Where should I start troubleshooting now? I've already unlocked the heating system. The error has occurred again.
Andreas
Translated on 06-10-2026, 3:21.
brezelmann01 likes this.
Post07-10-2017, 13:49    Subject: Webasto Heater Problems Sharan 7N Quote
Test: With the engine running and cold, turn on the auxiliary heater and observe the temperature values using VCDS. If everything is working correctly (i.e., water is circulating through the engine water pump while the engine is running), then proceed to the next test: with the engine off, if the temperature becomes too high and the heater shuts off, then the circulation pump is likely defective.
If the error persists even when the system is cold and the temperature reading is too high, then the temperature sensor is likely defective.
Translated on 06-10-2026, 3:26.
vag-driver
Post08-10-2017, 11:00    Subject: Webasto Heater Problems Sharan 7N Quote
I ran the SHZ (presumably a heating, ventilation, and air conditioning system) with the engine off. After the fan starts and the heater turns on, it starts making knocking and rattling noises. Then, the heater goes into shutdown mode, and only the interior fan continues to run. If it's just a fault, it's likely of a mechanical nature.
I don't have any error entries anymore icon_rolleyes.gif.
Andreas
Translated on 06-10-2026, 3:27.
Post08-10-2017, 12:52    Subject: Webasto Heater Problems Sharan 7N Quote
vag-driver wrote:
I ran the SHZ (heating, ventilation, and air conditioning system) with the engine turned off. After the fan starts and the heater turns on, it starts to make knocking and rattling noises. Then, the heater goes into the shutdown process, and only the interior fan continues to run. If it's just a fault, it's of a mechanical nature.
It's quite possible that the heating system is overheating - repeat the test with the engine running !!!! icon_idea.gif
Translated on 06-10-2026, 3:28.
vag-driver
Post08-10-2017, 17:09    Subject: Webasto Heater Problems Sharan 7N Quote
I drove today with the traction control system (TCS) activated, and I felt that it was working correctly.
Using VCDS in service mode, I performed the basic settings and observed the following:
1. It's still rattling and sputtering.
Within a short period, the heating water temperature rose above 100°C, at which point the heating system shut off.
There are still no error entries in the memory.
Andreas
Translated on 06-10-2026, 3:29.
vag-driver
Post09-10-2017, 9:06    Subject: Webasto Heater Problems Sharan 7N Quote
I spoke with a repair technician and described the problem. It's likely the circulation pump.
Since it's an on-site installation, he needs the model type and a picture of the pump housing, specifically showing the outlet connections. With that information, he can provide the appropriate pump.
Report back when you have time.
Andreas
Translated on 06-10-2026, 3:30.
Post09-10-2017, 16:09    Subject: Webasto Heater Problems Sharan 7N Quote
vag-driver wrote:
Since it's an OE installation, he needs the model type and a picture of the pump housing, specifically showing the outlet connections. Then, he can provide the appropriate pump.
Using the original part number from the VW spare parts catalog (AKTE), you can find the correct pump and photos (e.g., on eBay). This way, you don't have to disassemble the car and wait for parts to arrive.
You can also order them directly online. They are significantly cheaper there than from VW.
Greetings.
Guste.
Translated on 06-10-2026, 3:31.
vag-driver
Post10-10-2017, 8:25    Subject: Webasto Heater Problems Sharan 7N Quote
Greetings.
Guste
I have already done that icon_smile_thumb_up.gif.
Andreas
Translated on 06-10-2026, 3:32.
vag-driver
dieselschrauber likes this.
Post15-10-2017, 7:54    Subject: Webasto Heater Problems Sharan 7N Quote
Yesterday, I finally had the chance to replace the pump. Now I can finally use the STHZ again to its full extent. icon_smile_thumb_up.gif
Andreas
Translated on 06-10-2026, 3:33.
Post15-10-2017, 8:49    Subject: Webasto Heater Problems Sharan 7N Quote
Thank you for the feedback! Is the G18 actually installed in the pump, or how did the intermittent short circuit to ground occur?
vag-driver
Post15-10-2017, 15:25    Subject: Webasto Heater Problems Sharan 7N Quote
The G18 is externally mounted in the front bumper, according to RLF. I can't explain the error message. After clearing it, it didn't reappear. Attached is a picture of the opened, broken pump. When connected to the battery, you can see that the impeller cannot start on its own.
 File size:  3.09 MB
 Viewed:  2940 times
Andreas
Translated on 06-10-2026, 3:34.
vag-driver
Post03-12-2019, 21:18    Subject: Webasto Heater Problems Sharan 7N Quote
New Sharan, new game. icon_evil.gif The vehicle has approximately 50,000 km on the odometer.
Part number: 7N0 963 272 E
Component: Portable heater 044 4941
Revision: 00044000 Serial Number: 09028239000000
Encoding: 0031142
VCID: 377B1DD946063DFCD0-8062
4 error codes found:
00664 - Fuel level indicator.
002 - Lower limit exceeded - Intermittent.
Error status: 00100010
Error priority: 7
Error frequency: 4
Lost Count: 156
Mileage: 49486 km
Time: 0.
Date: 2019.12.01
Time: 09:52:53
000 - -
Error priority: 2
Error frequency: 1.
Lost Count: 119
Time: 0.
Afterglow.
Voltage: 12.07 V
Error priority: 3
Error frequency: 2.
Lost Count: 159
Mileage: 49618 km
Time: 0.
Date: 2019.12.03
Time: 16:18:36
Disturbance.
Voltage: 12.07 V
000 - -
Error priority: 2
Error frequency: 1.
Lost Count: 119
Time: 0.
The water pump of the STHZ has failed again. It's obviously a design flaw.
Andreas
Translated on 06-10-2026, 3:38.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater Errors: AutoScan Diagnostics On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. ABS Sharan, year 2006, error cannot be fixed Transmission, Chassis, Body & Interior
No new posts Auxiliary Heater for V6 TDI Engine Diesel Engine Technology
No new posts Standheizung??? Diesel Engine Technology
