TDI - AFN-Motor, Startschwierigkeiten, weißer Rauch, Ruckeln | Posts 48+
Go to page: Previous  1, 2, 3, 4
Post18-07-2018, 16:51    Subject: Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 29-08-2026, 23:07.
Kiko
Avatar-Kiko
1996 Volkswagen Golf
Post10-12-2019, 10:59    Subject: Crankshaft Bearing Failure: Common Causes & Fixes Quote
Dear forum members,
I'm writing back (unfortunately).
The repair using the special milling tool was carried out 2 1/2 years ago and has now covered approximately 50,000 km.
My Golf now has 510,000 km on the odometer, which is quite a respectable amount of mileage.
The car has been parked for a while now (about 2 months) because we are expecting twins, and my wife isn't using her car at the moment. That's why I've been driving her car more often.
On December 4th, the car was due for its technical inspection (TÜV), so I wanted to drive it a bit beforehand. On December 2nd, I drove to work and back. Then, on December 3rd, the car wouldn't start in the morning. It had the same symptoms as before: a lot of white smoke, a strong smell of unburned diesel, etc.
In the afternoon, I scanned for errors using VCDS, and the result was:
Error code 00575 - Intake manifold pressure 17-10 - intermittent.
Error code 00550 - Injection start control 17-10 - Regulation difference - intermittent.
So, I'm pretty sure the "killer bolt" has come loose again, which means the valve timing or injection timing is no longer correct.
The problem with the intake manifold pressure might actually be caused by a vacuum hose leak. I replaced that hose some time ago, but I didn't clear the error code. So, it could be an old error that's still showing up.
My problem: Unfortunately, I parked my Golf 200 meters away from home on the street. In my garage, I have my Mercedes "W124" with the transmission removed (the clutch needs to be replaced).
Therefore, my question is: Can VCDS detect incorrect valve timing and incorrect injection timing, even if the engine does not start (i.e., while it is cranking)?
I don't necessarily want to have to remove valve covers, etc., on the side of the road in order to read the values mechanically.
Also, the two girls could be born at any moment, and then I'll have to take on completely different responsibilities.
Thank you for any contributions, and I wish you a happy Christmas season.
Kiko.
Translated on 29-08-2026, 23:10.
Post10-12-2019, 21:30    Subject: Quote
Therefore, my question is: Can VCDS be used to detect incorrect valve timing and incorrect injection timing, even if the engine does not start (i.e., while it is cranking)?
I see 2 possibilities:
a) You don't care what happens, you just want to get the car onto your property. You can try to start it in first gear using the starter and drive it home. After that, you can calmly dismantle it, dispose of it, etc.
b) Motivate a few people to help push.
I don't know if I would have the motivation to remove the timing belt again at that mileage... icon_eek.gif
It's quite a bit of work, actually.
Translated on 29-08-2026, 23:13.
dieselschrauber likes this.
Post15-12-2019, 5:52    Subject: Quote
Just check the crankshaft and fuel injection pump. If the crankshaft pulley is misaligned, the locating pin in the fuel injection pump will no longer fit properly.
Translated on 29-08-2026, 23:15.
No new posts Sharan 2.0 TDI BRT - Jerking/Hesitation when engine is warm Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: PD Motor Stalling When Accelerating, Tandem Pump Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
This topic is locked, you cannot edit or reply. 2.0 TDI - Germany - Engine misfiring, white smoke Diesel Engine Technology
No new posts Audi 2.5 AKE: White Smoke & Power Loss? On-Board Diagnostics (OBD)
No new posts VS Golf 2.0TDI BKD - stalls at start + white smoke Transmission, Chassis, Body & Interior
No new posts 2.0 TDI 16V A3 - Starting problems and rough idling Diesel Engine Technology
