VW Golf Sportsvan, 2015, with HEX-USB+CAN interface
Solarsepp
Post14-07-2020, 9:52    Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface Quote
I purchased the interface mentioned above from the "Dieselschrauber-Shop" in 2016. Okay, here's the translation:
"Now, I wanted to make some adjustments in the BCM, and I'm getting a message that..."
"This interface does not support sending telegrams larger than 256 bytes."
Is the interface really too outdated for my 2015 sports van?
 File size:  214.31 KB
 Viewed:  405 times
 Viewed:  333 times
Post14-07-2020, 19:44    Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface Quote
I recommend the 3-channel version of the HEX-V2 (if it's just for your own car).
https://shop.dieselschrauber.org/en/vcds-hex-v2-p-329.php
or for use in the workshop:
https://shop.dieselschrauber.org/en/vcds-interface-upgrade-p-342.php
Solarsepp
Post20-07-2020, 14:39    Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface Quote
Thank you for the quick response.
I have one more question - where can I find the license number? Is it likely that the serial number found in VCDS under "About" is the one we're looking for?
THANK YOU!
Post20-07-2020, 16:29    Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface Quote
What do you mean by "license number"? It's only available on the "About..." screen. Or are you referring to the serial number of the interface? It's located on the interface.
Solarsepp
Post20-07-2020, 16:44    Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface Quote
Hello Rainer,
Thank you for your feedback.
As far as I understand, when upgrading, I need the license number for the VCDS/Interface to verify that it is not a clone?
Josef
Post22-07-2020, 18:34    Subject: VW Golf Sportsvan, 2015, with HEX-USB+CAN interface Quote
You need a Screenshot of your "About..." screen. If you are a new customer or the interface is from a different source, please ensure the invoice is addressed to your name.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Service reset failed on Golf Sportsvan 2016 On-Board Diagnostics (OBD)
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
