a4b82.0tdi
11-07-2020, 22:54 Subject: Audi A4 B8: Reset Service Interval |
Hello everyone,
I have performed the oil service and inspections and reset the maintenance indicator â using longlife oil.
The oil service function worked, but when resetting the inspection service (for regions outside of Europe), the time since the last inspection was not updated.
Therefore, the dashboard displayed: "Inspection due for 160 days" and when starting the engine, it showed: "Inspection due!".
Now I've changed channel 55, which displays "Time since inspection," from 895 days to 3, and now it matches the information on the instrument cluster.
-Question: Shouldn't this value be automatically set to 0?
Attached is the error-free Autoscan report along with the values for oil service and inspection.
But I still get the message "Inspection due!" when starting and turning off the car.
-Maybe a value is incorrect?
And when I ran the car scan, the message appeared: "Stability program fault - see owner's manual."
However, I couldn't find anything about malfunctions in the user manual. And I can turn the ASR (Anti-Slip Regulation) and ESP (Electronic Stability Program) on and off while driving, and it also displays that they are active.
-What can I do to get rid of this message: "Inspection due"?
| Description: |
 Download |
| File name: |
Log-WAUZZZ8K5BA124556-240620km-Audi A4B8.txt |
| File size: |
12.03 KB |
| Downloaded: |
882 times |
| Description: |
 Download |
| File name: |
Log-240620km-Audi A4B8 Serviceintervall Werte.txt |
| File size: |
7.16 KB |
| Downloaded: |
785 times |
| Description: |
 Download |
| File name: |
Log-240620km-Audi A4B8 Serviceinspektion zurĂŒckstellen.txt |
| File size: |
2.47 KB |
| Downloaded: |
846 times |
Translated on 11-08-2026, 21:40.
Joined: 04/12/2002 Posts: 18134 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
13-07-2020, 19:03 Subject: Audi A4 B8: Reset Service Interval |
Hi.
Quote: | | Data as of: 20200518 DS317.0 |
There is a newer data version available, which also includes updated service reset functions. Please first install the latest version of VCDS from your customer account and try again.
Did you perform the reset using the assistant tool, which first reads the adaptation channels from the instrument cluster and then describes them accordingly, correct?
Generally speaking:
Service interval display / Maintenance interval display Audi
Translated on 11-08-2026, 21:43.
Profile PM WWW Garage |
a4b82.0tdi
22-07-2020, 19:57 Subject: Audi A4 B8: Reset Service Interval |
Hello.
I reinstalled VCWS yesterday and performed the service reset procedure again, but the "Service due!" message still appears when starting and stopping the engine.
I selected the option "Switch to flexible maintenance intervals (rest of the world/diesel engine)" in the "Service Reset" menu.
But as soon as I started it, the same error message appeared again, and it also shows up when I shut it down.
The automatic scan found no errors. However, during the automatic scan, a brief message appeared stating: "Stability program malfunction - see owner's manual."
I went to the ĂAMTC (Austrian Automobile Club) in Dornbirn today, and they used a Gutmann and a Bosch diagnostic tool to check the car, but they didn't find any errors.
- How can the service be stopped so that the error message no longer appears?
After starting the device, I changed the value of channel 02 from "service due" to "0 service". This was reflected in the log, but after restarting, the error message "service due!" reappeared, and the value of channel 02 reverted back to 1.
"Would it be possible or necessary to switch back to a fixed service interval without using long-life oil, and to individually adjust all the required parameters to 30,000 km, 730 days, and for long-life oil?"
And Rainer, what do you understand by "fundamentally" â with your link?
- Are you suggesting that I should first use the "Service Reset" option in the menu (is that the assistant?), and then correct certain channels?
Thank you for your help.
| Description: |
 Download |
| File name: |
Log-AUDI A4 B8-WAUZZZ8K5BA124556-240820km-4_Auto-Scan.txt |
| File size: |
12.05 KB |
| Downloaded: |
724 times |
| Description: |
 Download |
| File name: |
Log-AUDI A4 B8 3_nach_Service_RĂŒcksetzung_im_Kanal_02.txt |
| File size: |
2.47 KB |
| Downloaded: |
657 times |
| Description: |
 Download |
| File name: |
Log-Audi A4 B8 2_nach_Service_RĂŒcksetzung_mit_MenĂŒ.txt |
| File size: |
2.62 KB |
| Downloaded: |
655 times |
Translated on 11-08-2026, 21:46.
22-07-2020, 21:00 Subject: Audi A4 B8: Reset Service Interval |
"Could you please take a Screenshot of what you see when performing the service reset in VCDS, and show me the available options?"
Translated on 11-08-2026, 21:49.
a4b82.0tdi
27-07-2020, 21:12 Subject: Audi A4 B8: Reset Service Interval |
I have the software installed on a tablet PC, and it doesn't have a "print" button.
I found on Google that pressing the "Windows key + volume down button" should save a Screenshot, but unfortunately, I didn't see any reaction, and I couldn't find any files related to it (from today's date).
Attached is a picture of the keyboard.
- Is there perhaps another keyboard shortcut that works?
| Description: |
| File size: |
3.72 MB |
| Viewed: |
11206 times |
29-07-2020, 18:27 Subject: Audi A4 B8: Reset Service Interval |
Perhaps you could take a picture of the screen with your phone instead of the keyboard? Just as a suggestion for another way to get a Screenshot...
Translated on 11-08-2026, 21:50.
a4b82.0tdi
29-07-2020, 20:48 Subject: Audi A4 B8: Reset Service Interval |
Okay, I'll do that tomorrow evening.
Translated on 11-08-2026, 21:51.
a4b82.0tdi
29-07-2020, 21:35 Subject: Audi A4 B8: Reset Service Interval |
I also received information that for these engines, it's important to pay attention to the soot value or soot level after driving over 180,000 kilometers.
- Could that be the reason why I'm still getting the "Service due" message?
- Does anyone here have experience and might be able to help?
Thank you in advance.
29-07-2020, 21:47 Subject: Audi A4 B8: Reset Service Interval |
Quote: | Read and follow the link I provided. Your control unit uses UDS, so:
/viewtopic.php?t=28677 |
It's very likely to be the same.
a4b82.0tdi wrote: | I also received information that with these engines, it's important to pay attention to the soot value or soot level after more than 180,000 km.
Thank you in advance | .
Just have the person who gave you this information explain it to you directly.
As it stands written, it's nonsense; perhaps he meant something else, but no one here can know that.
Translated on 11-08-2026, 21:53.
a4b82.0tdi
30-07-2020, 8:11 Subject: Audi A4 B8: Reset Service Interval |
Here are the options:
| Description: |
 Download |
| File name: |
VCDS Möglichkeiten Wartungsintervalle.pdf |
| File size: |
247.19 KB |
| Downloaded: |
446 times |
Translated on 11-08-2026, 21:54.
30-07-2020, 20:29 Subject: Audi A4 B8: Reset Service Interval |
Verstehe das Problem nicht... Everything is there.
Switch to flexible maintenance intervals, for the rest of the world, diesel engine. Usually unnecessary, just because you clicked something somewhere before.
Reset flexible oil change service for long-life intervals, applicable to vehicles outside of specific regions and with diesel engines.
Reset additional tasks.
4. Reset inspection service, rest of the world.
5. Exit the control unit with the "back" button.
6. Ignition off for 5 seconds.
7. Ignition on.
8. Report here.
Translated on 11-08-2026, 21:55.
Herbert Profi-Schrauber
dieselschrauber likes this. |
30-07-2020, 20:38 Subject: Audi A4 B8: Reset Service Interval |
Hi there,
As someone who has driven an A4 B8 with varying degrees of success (see my signature), I'd like to offer my input.
The "Oil change due" message is cleared by setting two adaptation channels (APKs) to "0", namely "kilometers since..." and "time since...", and then resetting the APK for the service message.
Similarly, for "Inspection due," there are two other APK fields: "kilometers since..." and "time since...".
For now, I'm leaving out the details regarding tasks that are time- or mileage-based (such as brake fluid changes and timing belt replacements).
Translated on 11-08-2026, 21:57.
a4b82.0tdi
31-07-2020, 7:21 Subject: Audi A4 B8: Reset Service Interval |
Good morning.
Thank you - that's a very good and clear answer, perfect for me as a layperson.
I will do it in the same order and report back.
Since the car won't be available for several days, it will take some time.
A big thank you â also to the second council.
Translated on 11-08-2026, 21:59.
31-07-2020, 10:25 Subject: Audi A4 B8: Reset Service Interval |
Hi there,
Perhaps regarding the Screenshot I posted earlier about "resetting maintenance intervals," I'd like to know, before using it, which adjustment channels each function accesses.
Otherwise, I prefer to reset things manually by installing individual APK files.
Incidentally, when resetting the inspection service, Audi/VW proceeds in two ways (at least that's how SSP 438 describes it). The mileage until the next inspection service is always set to the full 30,000 km interval (i.e., it is reset and the base value is changed). Example: Inspection at 58,000 km - a reset is performed with a new mileage of 32,000 km.
The runtime is set to the next event to be performed (or left as is), or a maximum of 730 days. Example: Inspection in July 2020. Brake fluid due in January 2021. Therefore, the time until the next inspection should only be 182 days.
Translated on 11-08-2026, 22:01.
a4b82.0tdi
09-08-2020, 19:16 Subject: Audi A4 B8: Reset Service Interval |
Hello everyone,
Okay, it finally worked! And great that the "Service due!" message has finally disappeared.
Rainer, it only worked when I followed that exact order.
Finally, a big thank you.
Best regards.
Translated on 11-08-2026, 22:03.
10-08-2020, 17:16 Subject: Audi A4 B8: Reset Service Interval |
Thank you for the feedback!
Translated on 11-08-2026, 22:04.
