T4 Circulation Pump Leak: Troubleshooting & Adjustment
Thehanseh
Post26-07-2020, 19:55    Subject: T4 Circulation Pump Leak: Troubleshooting & Adjustment Quote
Hello everyone,
I recently replaced the socket and shaft of the VEP (variable exhaust pressure) system on a 1995 ABL.
After that, the speed was increased by 300 RPM, and it was very difficult to bring it down to 900 RPM.
I also replaced the inner spring, as this is often a cause of poor idling, especially if it has become stretched during removal.
I've now adjusted the throttle lever by one notch as a test, but the idle speed remains the same, even though it should noticeably change. I had previously completely turned down the residual fuel adjustment.
What could be going on here?
Translated on 16-10-2026, 2:24.
dieselschrauber likes this.
Post26-07-2020, 23:44    Subject: T4 Circulation Pump Leak: Troubleshooting & Adjustment Quote
I'm not a VEP expert, and I've never even held one with a mechanical throttle cable.
For an electronic system, I would assume that the flow rate setting would need to be adjusted on the pump itself. I cannot determine whether this can be replicated in a mechanical system.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 16-10-2026, 2:26.
Post02-08-2020, 10:26    Subject: T4 Circulation Pump Leak: Troubleshooting & Adjustment Quote
It's a good idea to mark the position of the throttle lever on the shaft beforehand. I would recommend taking each step back by one tooth at a time.
No new posts VCDS: Adjusting Glow Plug Timer on VAG TDIs Troubleshooting & Guides
No new posts Einstellung der Einspritzdüsen/Düsenhalter eines VP-TDI Troubleshooting & Guides
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Distributor pump 068 130 107 H Diesel Engine Technology
No new posts Lucas fuel pump for VW and Skoda??? Diesel Engine Technology
No new posts RWG-Position at AFN? Diesel Engine Technology
No new posts Engine tuning box installation Diesel Engine Technology
