Air conditioner not cooling during speed fluctuations
Xbuman
Post14-09-2020, 22:10    Subject: Air conditioner not cooling during speed fluctuations Quote
I'm having a problem where the air conditioning stops cooling when the engine speed increases.
Seat Exeo, year 2010, 2.0 diesel engine, 143 horsepower.
The following actions were taken:
- Error memory is empty.
- Air conditioning service was performed.
- The two fans on the condenser are running / do not run when in ECO mode.
- Compressor current, according to VCDS, is between approximately 0.3 and 0.65 A.
- High-pressure generator (G65) idling pressure: 10 to 14 bar.
- The high-pressure fuel injector (G65) is not delivering the required pressure (6 bar) when increasing engine speed.
- Last shutdown condition 1.0 (according to VCDS).
Notably, the compressor draws 0.65 amps, but the pressure is not reaching 6 bar.
Does anyone know where the problem might be?
Herbert likes this.
Post14-09-2020, 22:47    Subject: Re: Air conditioner not cooling properly with fluctuating fan speed Quote
What does VCDS display as the explanation for "deactivation condition 1"?
If the compressor is powered on but not building pressure, it's likely seized. It's probably triggered the clutch. In case of a fault, record a video from the front side using your phone. That usually provides quite a good amount of information.
If everything is okay, I would check whether the current is actually flowing (by taking a measurement with a multimeter), or whether the control unit (STG) just wants the value to be a certain level (a pure setpoint value)...[/quote]
Xbuman
Post14-09-2020, 23:09    Subject: Air conditioner not cooling during speed fluctuations Quote
Thank you for the quick response.
The term "compressor current" refers to the control valve N280, which is specifically for the compressor.
According to VCDS, the compressor torque drops to 0 Nm when the engine speed increases, and then rises to approximately 5-9 Nm as the engine speed decreases.
vag-driver
Post15-09-2020, 7:59    Subject: Air conditioner not cooling during speed fluctuations Quote
Is the compressor's impeller intact?
Andreas
Xbuman
Post15-09-2020, 9:53    Subject: Air conditioner not cooling during speed fluctuations Quote
The take-up disc is fixed, and the compressor is not blocked.
vag-driver
Post15-09-2020, 10:03    Subject: Re: Air conditioner not cooling properly with fluctuating fan speed Quote
Please answer our questions if you want us to help you.
Andreas
Xbuman
Post15-09-2020, 18:24    Subject: Air conditioner not cooling during speed fluctuations Quote
Okay, I understand. Please provide the German text you want me to translate into English.
The compressor only has one connection, likely for the control valve N280.
 File size:  5.98 MB
 Viewed:  1325 times
vag-driver
dieselschrauber likes this.
Post16-09-2020, 8:46    Subject: Air conditioner not cooling during speed fluctuations Quote
The control valve is available as a separate part. However, I recommend replacing the entire compressor. Of course, this also includes the dryer.
Andreas
Xbuman
Post16-09-2020, 8:50    Subject: Air conditioner not cooling during speed fluctuations Quote
The master also suspected that the problem was related to the compressor.
But why should the dryer be included?
vag-driver
Post16-09-2020, 12:17    Subject: Air conditioner not cooling during speed fluctuations Quote
Because the circuit has been opened and the dryer is becoming saturated with moisture.
What kind of compressor do you have installed?
Andreas
Xbuman
Post17-09-2020, 13:07    Subject: Air conditioner not cooling during speed fluctuations Quote
The compressor and the dryer were replaced.
The high-pressure sensor (G65) now displays a minimum of 7 bar, and depending on the power output, it can increase to 13 bar. Simultaneously, the compressor torque increases with the pressure. The pressure sensor G65 now displays how the pressure is slowly increasing and decreasing, instead of showing abrupt bar values.
The compressor is also automatically switched off for a few seconds when the accelerator pedal is pressed hard, in order to maintain engine power. According to the Seat manual.
Compressor number: 4F0 260 805AP.
Thank you for your support.
vag-driver
Post17-09-2020, 13:57    Subject: Air conditioner not cooling during speed fluctuations Quote
I'm glad the feature is working again. Who performed the repair?
Andreas
Xbuman
cj77 likes this.
Post17-09-2020, 14:41    Subject: Air conditioner not cooling during speed fluctuations Quote
A small, reliable workshop. Compressor, dryer, and total labor costs: approximately 750.
The mechanic was either unaware of the issue related to climate control and engine speed, or unable to fully correlate the VCDS readings, but his assumption was correct.
I'm glad I have VCDS; it's already paid for itself.
No new posts A3 Climate Control Not Working: Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C air conditioning not cooling General Tips
No new posts Document A4, interior cools down too much Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran AC Not Working? Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts AC Not Cooling? Troubleshooting & Repair Tips. Transmission, Chassis, Body & Interior
No new posts Air conditioner not cooling - Year of manufacture 2000, c... Transmission, Chassis, Body & Interior
No new posts AC Not Cooling? Diagnose with VCDS. Transmission, Chassis, Body & Interior
