Seat Ibiza 6L engine swap, 118 kW
sir555freak
Post02-05-2021, 13:47    Subject: Seat Ibiza 6L engine swap, 118 kW Quote
Hello friends!
I'm new here.
We have an Ibiza 6L with a 1.9 TDI engine producing 130 horsepower, which has been chipped and is supposed to now produce 185 horsepower.
After a long time, this one has finally passed away.
We happened to get a 1.9 TDI engine with 118 kW (BOSCH) at a good price.
A well-known workshop manager has now installed it.
He took the PDE (performance data engine) and the chip from the old engine.
Unfortunately, we received the new engine without the accompanying operating instructions.
After reading the article "Tuning: Considerations for Intake Manifolds and Intercooling," I assume that the 118 kW engine has a larger intercooler than the 96 kW version.
Now I have a few questions.
Please provide the German text you would like me to translate into English. I will then give you only the translation, without any explanations.
What should I pay attention to when checking the LLK (coolant level) for the engine?
Can someone please tell me the required dimensions, such as size/volume, etc.?
(I have a limited budget, but the heat load calculation should definitely not be underestimated.)
2)
Does the 118 kW engine have a different turbocharger than the 96 kW version? If so, which one?
3)
Was war der Sinn hinter der Übernahme des Steuergeräts/Chips, oder war sie sogar kontraproduktiv?
Links to sources that would allow me to find the answers myself would also be great.
"Thank you very much!"
Translated on 16-07-2026, 15:45.
Post02-05-2021, 16:57    Subject: Seat Ibiza 6L engine swap, 118 kW Quote
1) Nothing, just use the original LLK. The LLK for engine code BUK (or for ARL) is excellent.
But first, check if there's enough space.
Regarding point 2: Yes, changing from GT1747VA to GT1749VB will result in different performance and control characteristics. Please refer to the search function or similar topics within this forum for more information.
3) Absolutely not a good idea, especially because of point 2.
"Alte" PDE mit erheblicher Laufleistung zu übernehmen kann je nach deren Zustand einen schnellen Tod des Tauschmotors bewirken. icon_idea.gif
"LG" translates to "Best regards" or "Sincerely" in English. It is a common abbreviation used at the end of emails and letters.
Translated on 16-07-2026, 15:49.
No new posts Broken sun visor clip for Audi, Seat, Skoda, VW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts Electrical problem in wet conditions, Seat Ibiza 6L ASZ Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts motortausch Diesel Engine Technology
No new posts Seat Ibiza 110PS TDI: Upgrade to G3 Diesel Engine Technology
No new posts Ibiza: Where is the NTC water connection? Diesel Engine Technology
No new posts GKB für langes 6g aus seat ibiza 6l 96kwmit 59,8kmh->... Diesel Engine Technology
