VW Passat 1,9 Tdi 1Z 5 Fehler u. a. G70 G81 G62 | Posts 16+
Go to page: Previous  1, 2
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-05-2021, 0:28    Subject: Quote
Hi there.
Try the next model. In the wiring diagrams, there's a version from 1996 onwards that includes the AHU. The AHU and 1Z are essentially the same.
Translated on 07-10-2026, 8:07.
tdi-erwin
Post15-05-2021, 7:11    Subject: Quote
Good morning!
Here's the translation:
"I will now describe the grounding connections for measurement purposes."
Vom Motorsteuergerät J 248 Stecker T 68 Pin 33 1mm braun/weiß, zu Punkt 220 (im Motorkabelbaum)weiter zu G81 Stecker T8a Pin 4 1mm braun/weiß, von Punkt 220 zu G 70 Pin 2 0,5 mm braun/weiß, von Punkt 220 zu G 28 Stecker T3 Pin 1 0,35 mm, und zu G 72 Pin 2 0,5 mm braun weiß, und zu G 62 Pin 3 0,5 mm braun/weiß. D
Di"The imaginary point 220 should be located in the engine wiring harness, and there must be a connection (solder joint/terminal) for the various cable cross-sections.
This is for the Passat with engine code AHU, manufactured from 10/1996 onwards.
I hope this helps.
TDI-Er"winThis imaginary point 220 is supposed to be located within the engine wiring harness, and there must be a connection (solder joint/terminal) to accommodate the various cable gauges.For Passat, engine code AHU, manufactured from 10/1996 onwards.I hope this helps.Best regards,TDI-Erwin.
Translated on 07-10-2026, 8:09.
Ich_Can_nix
Karma: +250 / -0   Thank you, like it!
Post15-05-2021, 13:31    Subject: Quote
On the Audi portal, the wiring diagram for the 1Z model is still available and can be accessed.
Fuel temperature sensor:
The value of -5.6°C is a substitute value (in case of a broken connection).
8-pin connector.
Pin 4 an Pin 33 vom Stg. Mass.
Connect pin 7 to pin 63 on the control unit.
Pin 63: When the ignition is on, check for a voltage between 1.5 and 3.5 volts relative to ground.
Coolant temperature sensor
4-pin connector.
Connect pin 1 to pin 33.
Connect pin 3 to pin 14.
Pin 14, when the ignition is on, measures approximately 1.5 - 3.5 volts relative to ground at 80 degrees Celsius. When heated to 80 degrees Celsius, the voltage decreases to approximately 1.5 volts.
The accelerator pedal sensor and mass airflow sensor are also connected to pin 33.
Best regards.
Michael.
Translated on 07-10-2026, 8:11.
MarcoB
Post15-05-2021, 13:57    Subject: Quote
Hello everyone.
Okay, regarding you, Erwin. On the A-pillar, underneath the trim for the hood release, I have a tangled bundle of ground wires. That's where they end. I'm going to pick up the car again shortly and continue searching.
To you, Mr. Know-it-all. Thanks for the information, I'll try again later.
Translated on 07-10-2026, 8:13.
Post17-05-2021, 9:49    Subject: Quote
The uncertainty regarding the wiring diagrams can be resolved. In the repair manuals (RLF) for the Passat, you can find a vehicle- and engine-specific section titled "Diesel Direct Injection and Glow Plug System." This section explains how to test the temperature sensors and wiring to the MSG (Engine Control Module), including contact assignments for a test box to be used between the MSG and the connector. These contact assignments are consistent with the MSG.
You can use this method to test any wire, including checking for shorts to either the positive terminal or the vehicle's ground.
You can also find the R/T curves of the temperature sensors in the RLF (presumably a reference manual or datasheet).
And please remember that pin 33 is a common reference point for some sensors on the MSG, but it does not necessarily have to be vehicle ground.
Translated on 07-10-2026, 8:14.
MarcoB
Post17-05-2021, 13:10    Subject: Quote
I also found information about Herbert, but it only describes the exam using the vag tester. Best regards.
Translated on 07-10-2026, 8:16.
dieselschrauber and Rüdi likes this.
Post17-05-2021, 13:30    Subject: Quote
You can easily measure the resistance with a multimeter between the contacts on the MSG connector and the respective sensor. icon_idea.gif
You don't need a VAG diagnostic tool for that.
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts EPB Passat 3C error On-Board Diagnostics (OBD)
No new posts Passat 2002 ABS/ESP Fehler On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. DSG Problems Passat CC - Solved On-Board Diagnostics (OBD)
No new posts Passat B4 1.9 TDI: Error 00546 Troubleshooting On-Board Diagnostics (OBD)
