CAAC Ruckeln zw. 1700 und 2000U/min nur ab 65% Last | Posts 16+
Go to page: Previous  1, 2
derkanter
Post13-06-2021, 17:43    Subject: Quote
The described problem only occurs under load. It does not occur when the system is idling, nor in other operating states. The higher the gear and the heavier the load, the more noticeable it becomes... Also, in gears 5 and 6, after 3000 RPM, nothing much happens except for a slight jerking.
Fahrzeug t5.2 Caravelle 2.0 CAAC, langer Radstand
Translated on 07-07-2026, 7:51.
Dagomanu
Karma: +55 / -0   Thank you, like it!
Post13-06-2021, 22:04    Subject: Quote
You can try the following: Re-calibrate all injectors (IMA-ISA). Bring the engine to operating temperature. On a suitable stretch of road (e.g., a quiet country road or a nearby section of highway), accelerate the vehicle to approximately 100 km/h. While in 4th/5th gear (or in gears 5-7 for DSG transmissions), transition to coasting mode as smoothly as possible by gently releasing the accelerator pedal. Allow the engine speed to drop as much as possible, ideally without using the brakes, to approximately 1300 rpm (or as low as possible). Repeat this process 5-10 times. After turning off the engine, the engine control unit (ECU) must remain inactive for at least 30 seconds. Allow for a warm-up period. (Avoid quickly switching the ignition on/off (position 15) within the first 30 seconds after turning off the engine using the ignition key!).
Best regards, Dago.
Translated on 07-07-2026, 7:52.
derkanter
Post13-06-2021, 22:45    Subject: Quote
Hey Dagomanu, what's the purpose of this?
Translated on 07-07-2026, 7:54.
Dagomanu
Post13-06-2021, 22:55    Subject: Quote
This procedure once helped me eliminate the jerking issue in a CAY engine. The instructions for this come directly from VW. It involves the engine control unit (ECU). It learns and stores the driving behavior, so I suspect that it might change or overwrite the existing behavior.
It's a different engine, but it's worth a try.
Best regards, Dago.
derkanter
Post13-06-2021, 22:56    Subject: Quote
Thank you for that, it's worth a try icon_smile_thumb_up.gif.
Translated on 07-07-2026, 7:55.
Post14-06-2021, 18:48    Subject: Quote
Dagomanu wrote:
You can try the following: Re-calibrate all injectors (IMA-ISA). Bring the engine to operating temperature. On a suitable stretch of road (e.g., a road with little traffic or a nearby section of highway), accelerate the vehicle to approximately 100 km/h. With 4th/5th gear engaged (or in the 5th-7th gear range for DSG transmissions), transition to coasting mode with minimal load by gently releasing the accelerator pedal. Allow the engine speed to drop as much as possible, ideally without using the brakes, to approximately 1300 RPM (or as low as possible). Repeat this process 5-10 times. After stopping the engine, the engine control unit must remain inactive for at least 30 seconds. Allow for a warm-up period. (Avoid quickly switching the ignition on/off (position 15) within the first 30 seconds after turning off the engine using the ignition key!).
Best regards, Dago
Translated on 07-07-2026, 7:56.
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku V6 TDI AKE/AYM - Jerking and Lack of Power Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BPW Shaking on Audi A4 TDI: Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ganz leichtes Ruckeln zwischen 1200 und 2000U/min 96kW PD? Diesel Engine Technology
No new posts VW T5.2 CAAC Error P0087: Causes & Fixes Diesel Engine Technology
No new posts CAAC 2.0 CRDI Injector Noise / Valve Rattle Diesel Engine Technology
No new posts Jerkiness at 1700-1900 RPM Diesel Engine Technology
