CBBB Motor in Tiguan, no compression on cylinders 1 and 2.
david7x64
Post11-05-2020, 19:20    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
Hello, I'm experiencing the following problem with a Tiguan 1 with the 170hp CBBB engine:
The engine is not taking fuel well and has less power at low speeds. Jerks severely.
The injectors would be replaced and reprogrammed after a complete overhaul.
The engine initially ran better, but then only ran very poorly. We then performed a compression test. Result: Cylinder 1 and 2: No! (0) Compression.
What could it be? The car needs to go to the workshop next week. Does anyone have an idea?
Best regards, David
Held467
Post11-05-2020, 20:29    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
It's likely that the head gasket has blown.
Best regards.
Post11-05-2020, 21:46    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
Without compression on individual cylinders, the only solution is to remove the head. The injectors and spark plugs should hopefully be installed correctly and be airtight, which is easy to see.
Best regards, Rainer
aquablader
Post03-08-2021, 15:58    Subject: Curiosity Quote
And, what was the ultimate reason, then? I'm facing a similar situation: the first two cylinders have no compression, the cylinder head is removed, the valves appear to be okay, and the piston crowns appear to be okay.
VG Ingo
david7x64
Post03-08-2021, 16:07    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
Hi, the headpiece was broken. Burned through between the cylinders.
Most likely caused by the poor injectors.
aquablader
Post03-08-2021, 16:12    Subject: Thank you. Quote
Thank you for the response.
The poem was okay here...
Post06-08-2021, 8:16    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
Then the device was faulty or it was used incorrectly…
aquablader
Post06-08-2021, 9:29    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
What are you trying to tell me?
Herbert likes this.
Post06-08-2021, 15:58    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
If the light bulbs are installed and sealed, and the valves are closed and sealed. If the cylinder head gasket and the cylinder head itself are undamaged, the piston is in place and moving, then there is nothing left but a measurement error, or?
aquablader
Post06-08-2021, 16:02    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
Who says that the pistons are in good condition? There were, in fact, two rings broken.
However, at the time the post was created, I didn't know this and therefore inquired further.
david7x64
Post06-08-2021, 17:32    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
If the light bulbs are installed, you cannot measure compression...
dieselschrauber likes this.
Post07-08-2021, 7:09    Subject: CBBB Motor in Tiguan, no compression on cylinders 1 and 2. Quote
Okay, as of August 3rd, nothing had been written about it yet. Then the cause has been found.
Of course, it is correct that the light bulbs are removed for measurement purposes. Then I remove the light bulb and say injector.
But it's great that it's been resolved.
No new posts Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts FSE Premium Retrofit for Passat, Golf, Tiguan Troubleshooting & Guides
No new posts VE Injection Pump Data: 5-Cylinder Engine Performance Technical Data
No new posts A4 2.5 TDI: No Compression in Cylinder 2 Diesel Engine Technology
No new posts Too much oil pressure, no compression, AFN engine Diesel Engine Technology
No new posts Asche volume at Motor CBBB Diesel Engine Technology
This topic is locked, you cannot edit or reply. Tiguan 2.0 TDI: Intermittent Starting Issues (Warm Engine) Diesel Engine Technology
