Audi A6 C6 multi-link rear axle
vag-driver
Post21-09-2021, 10:00    Subject: Audi A6 C6 multi-link rear axle Quote
I will soon be installing the complete Meyle HD control arm kit on the aforementioned Audi, and I will also be replacing the suspension at the same time.
1. What is the shank size used for the rear shock absorber?
"The upper control arms have already been replaced, but they have broken again. Therefore, I can no longer rely on the current alignment. Is there a specific angle requirement for the installation? How can I ensure the correct initial alignment?"
Andreas
Translated on 09-07-2026, 10:12.
dieselschrauber likes this.
Post21-09-2021, 14:02    Subject: Audi A6 C6 multi-link rear axle Quote
You'll find the most reliable and comprehensive information about the required specifications through the vehicle-specific search (using the VIN) in ERWIN. You can download the model-specific manuals. And then, you need to use the shock absorbers that are appropriate for the specific vehicle configuration.
Translated on 09-07-2026, 10:13.
vag-driver
Post21-09-2021, 15:04    Subject: Audi A6 C6 multi-link rear axle Quote
I have the documents, but I skimmed over them too quickly icon_rolleyes.gif.
Only the T10001/9 socket adapter is to be used.
Andreas
Translated on 09-07-2026, 10:14.
Post21-09-2021, 15:24    Subject: Audi A6 C6 multi-link rear axle Quote
To get a more detailed look, I would like to know:
Year of manufacture, engine, drive type, rear-wheel drive or front-wheel drive.
vag-driver
Post21-09-2021, 15:39    Subject: Audi A6 C6 multi-link rear axle Quote
0588 AAS
First registration: 06/2007.
V6 ASB 171 kW
Quattro.
I'm interested in both recordings of the shock absorber pistons. The front ones should require a 6mm or 7mm Allen key. The rear ones, as usual, have a pin profile.
Thank you very much.
Andreas
Translated on 09-07-2026, 10:15.
Post21-09-2021, 16:27    Subject: Audi A6 C6 multi-link rear axle Quote
Although the model codes for the transmission and axle drive are still missing, the images are quite clear with the currently available options.
Translated on 09-07-2026, 10:16.
vag-driver
Post21-09-2021, 16:35    Subject: Audi A6 C6 multi-link rear axle Quote
What type of pin profile is used on the back? Is it 5 x 8 mm or 6 x 8 mm?
Andreas
Post21-09-2021, 16:41    Subject: Audi A6 C6 multi-link rear axle Quote
You are now asking about a detail that is likely not mentioned in the manuals, but can only be determined from the parts list.
But without the identifying letters, you might not even look at the right document.
vag-driver
Post21-09-2021, 18:45    Subject: Audi A6 C6 multi-link rear axle Quote
I don't have the GKB manual available right now. Where can I find information about the type of axle drive used?
Andreas
Translated on 09-07-2026, 10:17.
Post21-09-2021, 19:13    Subject: Audi A6 C6 multi-link rear axle Quote
You can find it on the storage medium. Usually, it's located in the trunk and glued into the service booklet.
vag-driver
Post22-09-2021, 21:41    Subject: Audi A6 C6 multi-link rear axle Quote
Can anyone tell me which ball joint separator fits the lower control arms?
Andreas
Post23-09-2021, 9:17    Subject: Audi A6 C6 multi-link rear axle Quote
Andreas,
If you don't say anything specific, all we can do is guess.
Vorne oder hinten? Inside or outside?
Should I press the control arm out of the hub or the control arm joint out of the wheel bearing housing?
Most printing blocks can be carved by hand. That's how I did it. You just need to adapt the design to the material you're using.
Based on the questions, I can only assume that you are working without the original RLF (Richtlinien für den Luftfahrtflugbetrieb - Guidelines for Aircraft Operation). This means you don't have any specified take-off moments, angle settings, or regulations regarding the empty weight configuration.
One hour of Erwin (siehe Fehlerdatenbank) access costs €8.33, including the "fairytale tax." During that time, you can download the complete dataset for the vehicle.
P.S. - I'm signing off now.
Translated on 09-07-2026, 10:18.
vag-driver
Post23-09-2021, 10:38    Subject: Audi A6 C6 multi-link rear axle Quote
Of course, I am working with the RLF. As mentioned above, I have the documents.
To answer my own question, the tool T40042 is used. It is also available from Hazet as part number 1790-4 or from Kukko in the 129-3-A series.
Andreas
Translated on 09-07-2026, 10:20.
vag-driver
Post07-10-2021, 11:16    Subject: Audi A6 C6 multi-link rear axle Quote
It is done. What a job... But the result is convincing. The car now handles through the curves with the Meyle HD control arm kit, causing all objects that are not securely fastened to fly through the interior icon_biggrin.gif.
The upper control arms had already been replaced in the past and had broken again. My suspicion was confirmed that they had been installed in the wrong position. In the process, they even damaged the thread of the upper mounting bracket of the shock absorber, so I had to replace that as well.
The purchase of the Hazet spring strut tool set and the Kukko extractor has proven to be worthwhile.
Andreas
Translated on 09-07-2026, 10:21.
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi 80 B4 On-Board Diagnostics (OBD)
No new posts LOG Audi 2.5 AKE Upload
No new posts Audi AFB STG: Repair & Replacement Diesel Engine Technology
