Herbert Profi-Schrauber
19-09-2021, 20:13 Subject: Primer filler for plastic parts |
It's about repairing scratches in the plastic bumpers.
What should you use to prime before touching up with a paint pen or spray paint (i.e., not a full paint job)?
Herbert. Horch A4 8K CJCD
vag-driver Profi-Schrauber
dieselschrauber and Herby18451 likes this. |
20-09-2021, 8:34 Subject: Primer filler for plastic parts |
Depending on the severity of the damage, I would use filler. Viele Grüße
Andreas
dieselschrauber likes this. |
20-09-2021, 9:04 Subject: Primer filler for plastic parts |
Sure, here's the translation:
"This is about plastic as a substrate, not metal."
20-09-2021, 9:26 Subject: Primer filler for plastic parts |
Andreas
20-09-2021, 10:15 Subject: Primer filler for plastic parts |
First of all, thank you for your effort. I can find the type of product you're looking for, but if you read the descriptions carefully on the retailer's website (in the link) and on the manufacturer's website:
Quote: | Adheres to iron, steel, zinc and, with appropriate pretreatment, to aluminum, as well as to surfaces that can be overcoated.
in the usual plastics used in the passenger car sector |
Quote: | | Do not process on thermoplastic substrates |
I assume that the bumpers, in particular, are made of thermoplastic material. I can soften and reshape them by heating them with a hot air gun. That's how I get rid of the bumps.
20-09-2021, 11:14 Subject: Primer filler for plastic parts |
I would call there and get some advice. Viele Grüße
Andreas
20-09-2021, 12:06 Subject: Primer filler for plastic parts |
Having sought advice and experience, I intentionally asked the question here. At the dealer, at best, you'll get excerpts from the datasheet read to you, along with a glowing description of the products in their portfolio.
JMS
Joined: 01/13/2018 Posts: 31 Karma: +8 / -0 Location: Bückeburg
Herbert likes this. |
29-09-2021, 9:23 Subject: Primer filler for plastic parts |
Hello Herbert,
Last year, I repaired the bumper of my daughter-in-law's Polo. I used regular body filler. The result was very good, and the condition remains unchanged to this day.
Jörg.
29-09-2021, 11:43 Subject: Primer filler for plastic parts |
Hi Jörg,
Are we talking about standard spray fillers, like the ones used for car bodywork?
JMS
30-09-2021, 6:36 Subject: Primer filler for plastic parts |
Hello Herbert,
Yes, just regular spray paint from a can. I used it like that on a Fiesta a few years ago. And even there, there were no problems, until the vehicle reached the end of its lifespan.
I'm currently at work. When I get home, I can check to see if I still have the fountain pen (cartridge/ink). Then I could give you more information.
Jörg.
Sennator
JMS
29-10-2021, 9:56 Subject: Primer filler for plastic parts |
Sennator wrote: | | To fill scratches in plastic parts, you need plastic filler. |
I assume that filler was used previously if the scratches are somewhat deeper. In the described Polo, there was a hole in the bumper. I would have needed a *lot* of filler  .
Martininii
Joined: 02/28/2012 Posts: 137 Karma: +24 / -1 Location: Mitteldeutschland
dieselschrauber and Herbert likes this. |
09-10-2022, 22:06 Subject: Re: Primer filler for plastic parts |
Herbert wrote: | Hi,
Herbert |
"For small touch-ups with a paint pen, thorough degreasing is usually sufficient... or do you use a brush for larger areas?"
Here's how we do it when we're painting:
1. Thoroughly degrease.
2. Sand very smoothly, using 400-grit sandpaper, or even finer grit if sanding by hand.
3. Apply a plastic primer (available as a spray can) otherwise it might peel off.
4. Filling and sanding.
5. Paint...
When using filler from a can, it's important to sand it down very finely, and it's best to do so when it's still wet. Caddy 3 mit BLS Motor, 105PS, DPF (0603/AGB)
Renault Laguna 2 mit F9Q Motor, 107PS/120PS (3004/158)
