A6 c5 2.5 TDI engine cuts out while driving
BerniA6
Post22-10-2021, 0:42    Subject: A6 c5 2.5 TDI engine cuts out while driving Quote
Hi everyone,
I'm having a problem with my Audi A6 C5, 2.5 TDI engine (BDG), 163 hp.
The a6 suddenly shut off while driving, and this has happened before. It starts up again, but not always normally. I read the error codes with VCDS at home, and the error message is 0550, "fuel injection control, 27-10, implausible signal, intermittent." I've already replaced the diesel filter with the valve.
Replaced temperature sensor. Cleaned mass airflow sensor.
"There are no air bubbles in the transparent tubing. Do you have any idea what might be causing this?"
 File size:  3.09 MB
 Viewed:  997 times
Post22-10-2021, 13:37    Subject: A6 c5 2.5 TDI engine cuts out while driving Quote
Autoscan?
The electronics in the fuel injection pump often fail in these engines. Other potential sources of error could be the power supply from the engine control unit (look for relay 109, which may have a different name in your vehicle).
dieselschrauber likes this.
Post22-11-2021, 7:06    Subject: A6 c5 2.5 TDI engine cuts out while driving Quote
Check for a broken cable.
Post03-12-2021, 13:23    Subject: A6 c5 2.5 TDI engine cuts out while driving Quote
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat gibt Schläge - ESP Leuchte geht an Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi shuts off while driving. LMM? Diesel Engine Technology
No new posts Golf III TDI '96: Engine Stalling While Driving Diesel Engine Technology
No new posts T4 2.5 TDI ACV Engine Failure While Driving Diesel Engine Technology
No new posts Audi A6 TDI: Glow Plug Warning Light On? Diesel Engine Technology
