Rüdi wrote: |
Hello.
Thank you for the responses. My thought was simply to change the code from 00016 to the original code 00003 for Quattro.
The engine control unit (ECU) installed is not the original one. When my friend's son bought the Quattro 5 years ago, a performance upgrade had been registered in the vehicle's documentation due to modified software in the ECU, but the modified ECU itself was no longer installed at that time.
When picking up the part, it was sufficient to show the other part number to the KÜS inspector.
I'm going to leave everything as it is.
Greetings Rüdi |
If you change your mind... I still have a set of Rainers large nozzles lying around... after my AFN launched its pulley and vibration dampers from the crankshaft onto the A7. X
Also, there's also quite a bit of other stuff here, like VNT17, a bag full of AM29F010B-70JI, and much more.
Okay, please provide the German text you would like me to translate.
