Engine control unit cannot be coded for manual transmission
Dracula
Post04-06-2021, 19:10    Subject: Engine control unit cannot be coded for manual transmission Quote
The engine control unit (ECU) EDC17C46 (03L 906 018 RG), with engine code CFGC, cannot be re-programmed from DSG (dual-clutch transmission) to manual transmission. While I can select the manual transmission option in the coding assistant, I receive an error message when confirming the coding: "Coding not accepted! Error 31: Invalid value range!"
 File size:  17.09 KB
 Viewed:  1201 times
 File size:  37.59 KB
 Viewed:  1691 times
Translated on 08-07-2026, 20:10.
Post04-06-2021, 19:26    Subject: Engine control unit cannot be coded for manual transmission Quote
Is this engine control unit with this VAG part number available in cars with manual transmissions?
Translated on 08-07-2026, 20:11.
Dracula
Post04-06-2021, 19:53    Subject: Engine control unit cannot be coded for manual transmission Quote
Hello Rainer,
Unfortunately, I can't tell you that. I didn't realize that the transmission of the donor vehicle was so important; I would need to do some research first.
Translated on 08-07-2026, 20:12.
Dracula
dieselschrauber likes this.
Post04-06-2021, 21:17    Subject: Engine control unit cannot be coded for manual transmission Quote
It appears that the software version was only available with DSG. icon_evil.gif
Translated on 08-07-2026, 20:13.
Dracula
dieselschrauber, Herbert and Turbinchen likes this.
Post05-06-2021, 15:56    Subject: Engine control unit cannot be coded for manual transmission Quote
With software version 03L 906 018 RK, the problem is solved. icon_biggrin.gif
Translated on 08-07-2026, 20:14.
david16v
Post03-01-2022, 10:50    Subject: Engine control unit cannot be coded for manual transmission Quote
...I'll chime in here.
After installing a used engine control unit, I'm now experiencing a similar problem. The coding in the engine control unit is 00000000. When I try to change the coding value (regardless of the value), I always get the message "Invalid value range."
I'm also experiencing similar issues with the ABS and parking brake control units, which are also incorrectly coded.
David.
Translated on 08-07-2026, 20:15.
Dracula
Post03-01-2022, 14:12    Subject: Engine control unit cannot be coded for manual transmission Quote
Hello David,
You need to check which coding options are allowed for the software version of your control unit, meaning which transmissions/engine features, etc., were originally available. You can only code what was originally offered. If you need a different coding, the easiest solution would be to purchase a control unit with the appropriate software version. The last two letters are crucial.
Translated on 08-07-2026, 20:17.
david16v
Post03-01-2022, 15:57    Subject: Engine control unit cannot be coded for manual transmission Quote
The problem is twofold: firstly, there is no more "original" control unit available, and secondly, the coding cannot be changed at all. For example, I cannot even change the coding to indicate that an "airbag is installed"...
Translated on 08-07-2026, 20:18.
Dracula
Post03-01-2022, 18:08    Subject: Engine control unit cannot be coded for manual transmission Quote
You must enter a completely valid encoding, not just individual features.
Even if you don't have the original, you need a version with software that covers all the existing features; otherwise, it simply won't work.
No new posts Gear oil change T6 manual transmission Troubleshooting & Guides
No new posts Document: Flange, Wave, Gearbox 012 and 01A Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit (ECU) Coding Diesel Engine Technology
No new posts A3 (8P) Steering Coding: S3 Issue in RNS-E? On-Board Diagnostics (OBD)
No new posts Golf VI: CAYC Engine Coding (or Not) On-Board Diagnostics (OBD)
No new posts Audi TT: Can't code central locking control unit. Help On-Board Diagnostics (OBD)
