TDI Injector Problems: Golf 7 Variant 1.6 CXXB
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
EGGE1990
Post13-01-2022, 19:55    Subject: TDI Injector Problems: Golf 7 Variant 1.6 CXXB Quote
We have this error message on this Golf, as shown in the picture, and we're not sure what to do next.
We have replaced a differential pressure sensor because regeneration was not possible before, which is now working again.
According to the inspection plan from Otis, the AGR (Automatic Gear Retarder) should be tested, but the test seems to be failing or stopping prematurely without a result.
The function test with VCDS indicates that everything is okay.
We compared the actual and target values using a reference vehicle, and they were almost identical.
 VCDS Ausdruck
 File size:  1.63 MB
 Viewed:  690 times
Translated on 02-10-2026, 4:02.
Post14-01-2022, 11:19    Subject: TDI Injector Problems: Golf 7 Variant 1.6 CXXB Quote
For such cases, I can offer:
https://shop.dieselschrauber.org/en/obd-support-key-p-112.php
That's it for now.
Translated on 02-10-2026, 4:03.
No new posts Golf 1J Repair: Rear Hatch Lock Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tankklappenentriegelung failure Golf 5 Variant Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Variable valve timing malfunction General Tips
No new posts ASD AFN Golf Variant: What do you think? Diesel Engine Technology
No new posts Lenkradheizung Golf 6 Variant Transmission, Chassis, Body & Interior
No new posts Golf 3 Variant Net Separator Grill Transmission, Chassis, Body & Interior
No new posts Octavia 1.6 TDI CXXB has jerky movements, clunks, and int... Diesel Engine Technology
