Backup encodings and adjustments with VCDS (Solution)
Dagomanu likes this.
Post18-01-2022, 13:03    Subject: Backup encodings and adjustments with VCDS Quote
To back up the current coding and configurations of all control units, the following procedure is used with VCDS:
- Autoscan (includes all coding options)
- Applications -> Control Unit Mapping -> Select all control units, adjust settings, and choose hexadecimal/raw data.
This allows you to restore the original coding and settings for each control unit using VCDS.
 File size:  87.63 KB
 Viewed:  3166 times
Ratings - Backup encodings and adjustments with VCDS
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts VW Touran Document, Alarm Triggered by Backup Horn Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Codierungen / Anpassungen bei Inspektion On-Board Diagnostics (OBD)
No new posts Unlock code adjustments, brake control unit, ESP, Mark 60 Transmission, Chassis, Body & Interior
No new posts Rain closure and backup horn close/open On-Board Diagnostics (OBD)
No new posts Touareg Comfort Control Unit - Coding On-Board Diagnostics (OBD)
