I will send you the
Autoscan.
Update:
Yesterday, the DPF light came on. Today, I drove 29 km to work at 2500 rpm on the highway, with VCDS connected.
After 10 minutes, the loading coefficient returned to 0%, and the light turned off again.
I've attached a picture I took while driving at 2500 RPM, showing the values displayed.
The differential pressure at 2500 RPM seems stable, which is a good sign, right?
After the regeneration, the load coefficient remained constant at 0, even after the ABS activation, during which I drove at 50 km/h for 10 minutes.
Sometimes, when I start the engine, the display shows "Oil level sensor - workshop." I've been ignoring this message so far.
When I drive in mode AB, VCDS shows an oil temperature of 150 degrees, which is not possible. I know that the sensor must be faulty.
Okay, so here's the thing. I was driving home from work, and for about 10 minutes, VCDS showed me the oil temperature, but the load coefficient was still stuck at 0%.
Suddenly, the oil temperature remained stuck at 38 degrees (it seemed to be frozen), and at the same time, the load coefficient suddenly increased, even though I was driving above 2500 RPM.
I suspect that my oil level sensor is malfunctioning intermittently and is telling the engine control unit (ECU) that the oil temperature is 38 degrees, which is why the load coefficient is increasing so quickly.
I'll measure it again for two days while driving to see if the load coefficient decreases when the oil temperature is displayed.
Is the oil temperature detected by the oil level sensor?
I would still appreciate your responses.
