Golf 6 horn not working
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Post12-06-2019, 16:53    Subject: Golf 6 horn not working Quote
The horn is not working on a Volkswagen Golf 6, first registration: 04/2012. The horn and fuses are in good working order. Relay swapped.
There is no signal reaching the horn connector.
BCM is broken icon_question.gif.
Error according to VCDS: (I need to update the VCDS software).
Wednesday, June 12, 2019, 4:03:39:22077
VCDS -- A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS Version: DRV 18.9.0.2
Data as of: 20181017 DS296.0
https://shop.dieselschrauber.org/en
Dealer/Workshop name: VW
Company number: 010 00032 000010
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Address 09: Central Electronics
Label file: DRV\1K0-937-08x-09.clb
Control unit part number: 1K0 937 086 M. Hardware: 1K0 937 086 M.
Component and/or version: BCM PQ35 M 110 0651
Encoding: 40180A3A88251AC0400800C8740081E44B510288736D8520648000200040
Operating number: WSC 01357 011 00200
VCID: 3A7F65FAB509A49ADB-806E
Error codes have been cleared.
"1 error found:"
03266 - Relay control for signal horn.
009 - Short circuit to ground.
Environmental conditions:
Error status: 01101001
Error priority: 2
Error frequency: 1
Lost Count: 87
Mileage: 185,832 km
Time: 0
Date: 2018.07.14
Time: 16:02:60
Class 15, Entry.
Voltage: 12.50 V
one
one
Size 50, SOLD OUT.
text
from
text
aus
Post12-06-2019, 17:03    Subject: Golf 6 horn not working Quote
Just checked: Dashboard control panel, measurement block 071, 3rd position. Horn function (pressed/not pressed) is working correctly. Error as described above, reappears immediately after deletion.
Post12-06-2019, 17:29    Subject: Golf 6 horn not working Quote
Hello Kai,
Is the electrical connection from the body control module to the horn relay in good working order? Does the relay click when the horn is activated? It usually boils down to either a faulty connector or a damaged cable.
dieselschrauber and Herbert likes this.
Post13-06-2019, 16:16    Subject: Golf 6 horn not working Quote
dieselschrauber wrote:
Hello Kai,
Best regards, Rainer
Neither a click nor any voltage, ground, or positive connection was detected.
Cause: A fuse was MISSING icon_twisted.gif.
After a lengthy search, I noticed that a fuse holder had a contact on both sides, whereas typically, fuse holders either have one contact or none where fuses are supposed to be inserted. Where there were contacts, I inserted a fuse. "Ugh, here we go again... honestly, you never stop learning." icon_rolleyes.gif
The owner doesn't even know if he himself removed the fuse or something, and it wasn't until the TÜV inspection that it was discovered that the horn wasn't working.
Post13-06-2019, 18:00    Subject: Golf 6 horn not working Quote
Thank you for your feedback!
dieselschrauber likes this.
Post14-06-2019, 17:06    Subject: Golf 6 horn not working Quote
Possibly an ADAC workshop check, or a verification of the customer's honesty icon_smile.gif.
Post10-09-2019, 19:06    Subject: Golf 6 horn not working Quote
Hmm, good question. He's a loyal customer, so I doubt he's trying to trick me.
It was already weird icon_confused.gif.
Karma: +1349 / -0   Thank you, like it!
Post10-09-2019, 20:33    Subject: Golf 6 horn not working Quote
The owner doesn't even know if he himself had removed the fuse or something, and it wasn't until the TÜV inspection that it was discovered that the horn wasn't working.
It couldn't happen to me; I use that thing almost every day.
Herbert likes this.
Post10-09-2019, 20:52    Subject: Golf 6 horn not working Quote
icon_lol.gif ditto
Bananasplash
Post13-10-2022, 18:50    Subject: Golf 6 horn not working Quote
Can anyone tell me where the horn relay is located in a Golf 6 GTI 5K0? According to my diagnostic tool, there is no signal at the relay.
Post13-10-2022, 19:30    Subject: Golf 6 horn not working Quote
If you already have a diagnostic tool, we would appreciate an Autoscan.
If no one can tell you right away, you can find the location of the relay in the vehicle-specific manual or wiring diagram.
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
Post15-10-2022, 19:08    Subject: Golf 6 horn not working Quote
While doing some research on my own, I came across a page that discusses the relay number 3 (horn relay) for the Golf 6.
"located in the 'Relay diagram, Type 2 / Relay holder via body control module'." It's probably located under the dashboard trim, just like in the Fabia 1.
So, the lower kick panel needs to be removed, and the relay bracket should be located directly above it on the left side.
Best regards from Hesse.
Richard.
Polo V 1,6 Tdi (CAY)
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 6X1 MJ 2002: Horn Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 1.9 TDI Automatic R won't start. Diesel Engine Technology
No new posts VW Golf III TDI: Engine Problems & No Start? Diesel Engine Technology
No new posts Clutch, sometimes it works, sometimes it doesn't. Transmission, Chassis, Body & Interior
No new posts 1Z fails to start/shuts down during operation (not relay ... Diesel Engine Technology
