Start/Stop is unavailable, what does the measurement block indicate?
Pegasus
Post18-10-2022, 20:38    Subject: Start/Stop is unavailable, what does the measurement block indicate? Quote
Hello everyone,
After the technician quickly and competently resolved my DPF issue, I had another question about the start/stop function. I thought that if the constant regeneration stopped, the start/stop function would also be reactivated, but, no...
"It" doesn't stop, it always shows the "not available" symbol next to the staircase display, which is a 3/4 circle with an "A" and a line through it.
I had it checked/read.
No-Go for Active Participants 8
System error: Start/Stop of active participants 0
System status of Start/Stop function master 1
What does the "8" mean? What prevents stopping?
Thank you,
Best regards, Michael
Karma: +1334 / -0   Thank you, like it!
dieselschrauber likes this.
Post18-10-2022, 21:58    Subject: Start/Stop is unavailable, what does the measurement block indicate? Quote
{QUESTION_ABOUT_CAR_SCAN}
And since it's a diagnostic topic, please check the forum rules.
Pegasus
Post18-10-2022, 22:04    Subject: Start/Stop is unavailable, what does the measurement block indicate? Quote
Autoscan, I'll do that on Saturday.
Let me take a look.
Post19-10-2022, 5:59    Subject: Start/Stop is unavailable, what does the measurement block indicate? Quote
I should take a look at them
(meaning the forum rules) when you register.
It's absurd to copy the data, which was read out by a third party ("friend"), and then piece it together and post it here. What are you going to do with the answer? Should I visit my acquaintances again?
At least it would be more helpful if he posted the problem with the original data here. Then the errors due to poor copying would at least be eliminated (e.g., calculated soot mass of 1.4 kg). And one would know what to do about it.
Pegasus
Post19-10-2022, 19:24    Subject: Start/Stop is unavailable, what does the measurement block indicate? Quote
Ah, that's why I couldn't find any rules either; my registration was over two years ago.
I don't have anything to read from, so I'll take a photo and make a copy. So far, the search function has always been sufficient for me.
The cars that I'm actually interested in still have carburetors!
No new posts 1.4 TSI CTHA basic settings not available in the engine c... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts Start-Stop Skoda Superb 3T On-Board Diagnostics (OBD)
No new posts Start/Stop vom System deaktiviert Electrical Systems, Vehicle Electronics, Multimedia
No new posts Disable Audi A4 8W Start Stop System On-Board Diagnostics (OBD)
No new posts Hand-made Start-Stop / general start behavior Diesel Engine Technology
