Consulting Guest
23-12-2022, 21:35 Subject: Audi A6 Vp44 issues after pump replacement |
Good evening, everyone.
I've been reading this forum for a while now, and I've reached a point where I'm stuck. I bought an Audi A6 Allroad with a faulty fuel pump. The Audi has a 2.5 TDI engine with the engine code BAU, manufactured in December 2004. I bought a new VP 44 fuel pump from Bosch and installed it. After that, the car wouldn't start because the immobilizer was active. To save myself some trouble, I sent the engine control unit (ECU) to a programmer, who deactivated the immobilizer and the pump lock. At that time, I thought I could bypass the immobilizer because I wouldn't have the immobilizer login code anymore. Today, I installed the ECU, and the car started right up. However, I'm getting a lot of error messages, and it feels like all the other control units remain deactivated even with the engine running. For example, the Airmatic system isn't working at all. Unfortunately, I currently only have a basic diagnostic tool, and the following error messages are displayed in the engine control unit's memory:
- Databus error in the powertrain.
- Engine control unit locked.
- Powertrain: No communication from the steering column module.
I have already contacted the programmer, and he tested my data on a control unit and could not find any problems.
My question is, does the new pump definitely need to be coded? Are there any people here who can help me, for example, with reading the WFS log and configuring the pump? I would also like to buy VCDS. The Audi was working perfectly fine before. Thank you for your help.
Sure, here's the translation:
'P.S. I'm from 44235.'
| Description: |
| File size: |
62.96 KB |
| Viewed: |
1852 times |
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
24-12-2022, 11:54 Subject: Audi A6 Vp44 issues after pump replacement |
Okay, I will translate the text. Please provide the text you want me to translate from German to English. I will only provide the translation, without any explanations.
and
Profile PM WWW Garage |
Consulting Guest
24-12-2022, 13:14 Subject: Audi A6 Vp44 issues after pump replacement |
Hey Diesel Mechanics,
Thank you for your links. I will calibrate and test the pump.
chli1976 Profi-Schrauber
dieselschrauber likes this. |
25-12-2022, 11:38 Subject: Audi A6 Vp44 issues after pump replacement |
Then, the person who unlocks the immobilizer should also provide the login information, provided they have stored it in the EEPROM and not in the flash memory.
VCDS
Consulting Guest
25-12-2022, 19:30 Subject: Audi A6 Vp44 issues after pump replacement |
Hey, I received the login information from the programmer and am now waiting for my vcds order.
Consulting Guest
27-12-2022, 13:25 Subject: Audi A6 Vp44 issues after pump replacement |
I have calibrated the pump, but nothing has changed. Could it be that my engine control unit (ECU) is possibly defective? Are there any people in this forum who can check that? Here is my current error log.
| Description: |
| File size: |
450.1 KB |
| Viewed: |
532 times |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1509 Karma: +644 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
27-12-2022, 17:54 Subject: Audi A6 Vp44 issues after pump replacement |
Hi.
Perhaps we can fix the existing errors as much as possible.
Profile PM Garage |
