Audischeuche
Joined: 12/15/2022 Posts: 24 Karma: +1 / -0 Location: Schleswig
05-01-2023, 23:12 Subject: |
But what exactly am I supposed to have exchanged?
VCDS displayed exactly what I specified, but it didn't show a value for cylinder 2.
The needle injector is located on the rear passenger side.
Sorry... & (emoji) Audi A4 Avant B6 V6 TDI S Line Bj.2004,
Volvo V70 D5 Bj. 2003
New Beetle 1,9 TDI PD Bj. 2002
Audi A4 Avant B6 1,9 S Line mit 131PS, Bj. 2003
Mercedes Vario 815, Fernreisemobil, Bj 1999/ 2022 4,3 l mit 150 PS
Translated on 15-08-2026, 19:06.
Audischeuche
05-01-2023, 23:26 Subject: |
Herbert Profi-Schrauber
dieselschrauber likes this. |
06-01-2023, 8:37 Subject: |
Hi there,
I don't want to suggest that you've done anything wrong. I'm just surprised that a value is appearing for cylinder 3 (the one with the NHG). I would have expected a value for cylinder 2. Perhaps someone else with more experience with the V6 TDI can offer some insight.
Unfortunately, your last photo appears as black to me.
Herbert. Horch A4 8K CJCD
Translated on 15-08-2026, 19:07.
Joined: 04/12/2002 Posts: 18118 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
Audischeuche likes this. |
06-01-2023, 11:43 Subject: |
/viewtopic.php?t=24014
Translated on 15-08-2026, 19:08.
Profile PM WWW Garage |
Audischeuche
06-01-2023, 21:29 Subject: |
Sorry, I took another look under the hood today, and the cable from the needle lift valve goes into the valve cover on cylinder 3.
I can't find any information online about which cylinder this is supposed to be.
But why does VCDS display values for all cylinders except cylinder number 2?
Holger. Audi A4 Avant B6 V6 TDI S Line Bj.2004,
Translated on 15-08-2026, 19:09.
dieselschrauber and Audischeuche likes this. |
07-01-2023, 16:13 Subject: |
Hi there,
We also agree that the injector with the NHG sensor is located on cylinder 3.
On VP TDI engines, the idle speed correction values are specified with reference to a particular injector. No correction value is then output for that specific injector. I've observed this on four-cylinder engines, specifically referencing cylinder 3, which also corresponds to the injector with the NHG code.
Bei den Sechszylindern wird aus welchem Grund auch immer Bezug auf Zylinder 2 genommen, das finde ich wiederholt so. Miracles...
In your case, the MSG (Motor Steuergerät - Engine Control Unit) is significantly reducing the injection amount for cylinder 3 in order to achieve even running, meaning that much more fuel is being injected than it should be. It seems like the injector itself might need to be replaced. Someone here with experience with older V6 TDI engines might know more.
You don't mention the engine temperature; for this test, the engine should ideally be at its operating temperature.
Could you perhaps upload another photo of the measurements here, preferably in a different format? The photo above appears black to me.
Translated on 15-08-2026, 19:11.
Audischeuche
07-01-2023, 19:00 Subject: |
Hello Herbert,
Thank you very much for the detailed feedback!
I let the engine run until it reached its operating temperature before taking measurements.
The data provided in the text corresponds to the Screenshot from the VCDS test.
Unfortunately, I no longer have it and cannot set it up.
The fuel injector for that cylinder is likely the problem; it's the one with the needle lift actuator. I'll try to get a new or refurbished one.
Thank you and best regards.
Translated on 15-08-2026, 19:13.
Audischeuche
14-01-2023, 21:17 Subject: |
Okay,
I purchased an injector nozzle with a needle lift adjuster from a recycler.
Just need to swap them out now...
I'm curious to see if it makes a difference.
Translated on 15-08-2026, 19:15.
