Fehler Ladedruckregelung, HILFE | Posts 16+
Go to page: Previous  1, 2
Karma: +1344 / -0   Thank you, like it!
dieselschrauber likes this.
Post02-02-2023, 9:50    Subject: Quote
Kalle81 wrote:
......The large turbocharger has a wastegate, while the smaller one is connected via a valve in the manifold.
Both vacuum cups are working, or, alternatively, the rods are easy to move.
Checked with actuator diagnostics?
Post02-02-2023, 14:55    Subject: Re: Error with turbocharger pressure regulation, HELP Quote
Kalle81 wrote:
5294 - Charge pressure control.
P154F00 (039) - Malfunction.
In the default setting, I have checked the turbocharger (a), as well as the biturbocharger (b) and the EGR, and everything is I.O.
Only when checking the boost pressure regulation (c) does it throw the aforementioned error.
I have inserted (a), (b), and (c) into the quote. We need to figure out exactly what is being targeted at (a), (b), and (c).
Is this all in the default settings? Are there any other settings available for the boost pressure control? What possibilities are there in actuator diagnostics?
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Boost Control Problem - Golf4 AXR Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty Load Pressure Control Engine Identifier BRE Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf AJM Error 17958: Troubleshooting & Photos On-Board Diagnostics (OBD)
No new posts Turbocharger Problems: Troubleshooting & Repair Upload
No new posts 1.4TDI MKB:ATL Fehler 17964 Ladedruckregelung Regelgrenze .. Diesel Engine Technology
No new posts TDI Timing Help: Strange Error Message? On-Board Diagnostics (OBD)
