Retrofitting GRA for VW T-Cross
Golf2022
Post08-04-2022, 6:50    Subject: Retrofitting GRA for VW T-Cross Quote
Good day.
I'm new here and I already have a question:
We have a VW T-Cross 1.0 from 2021.
MKB: DLAA
GKB: URG
The T-Cross only has a speed limiter, without ACC (Adaptive Cruise Control) or GRA (Gearbox Reconnaissance Algorithm) functionality. PR: 8T9
Is it possible to activate the GRA function using VCDS?
If so, how?
Thank you very much!
Post08-04-2022, 6:54    Subject: Retrofitting GRA for VW T-Cross Quote
Good morning.
Please initiate a full system scan.
Golf2022
Post11-04-2022, 12:51    Subject: Car Scan Quote
Good day.
Attached is the Autoscan report for the T-Cross.
Log-WVGZZZC1ZMY085316-11650km.txt
 File name:  Log-WVGZZZC1ZMY085316-11650km.txt
 File size:  23.99 KB
 Downloaded:  1012 times
 File size:  23.99 KB
 Downloaded:  920 times
Golf2022
Post11-04-2022, 12:57    Subject: Retrofitting GRA for VW T-Cross Quote
Here's another photo of the steering wheel, hopefully it's helpful...
The keys would be available.
 File size:  76.99 KB
 Viewed:  2342 times
vag-driver
dieselschrauber and Turbinchen likes this.
Post11-04-2022, 15:20    Subject: Retrofitting GRA for VW T-Cross Quote
I suspect that this coding cannot be performed with VCDS. It probably only works through the central server to ensure that the equipment list is correctly stored in the database, so that the coding isn't reset again during the next visit to the workshop.
Andreas
Post16-04-2022, 10:19    Subject: Retrofitting GRA for VW T-Cross Quote
I wouldn't give up icon_wink.gif so quickly.
Could you please review the coding options available in the engine control unit (01) and adaptive cruise control (13)?
CUBE
dieselschrauber likes this.
Post16-04-2022, 12:13    Subject: Retrofitting GRA for VW T-Cross Quote
For the car, the GRA (presumably a feature or system) is activated via SwaP, which means it must be unlocked by Volkswagen. Only after this unlocking can you use VCDS for coding. (However, it would be advisable to have Volkswagen perform the coding directly.)
Since the bits are not described here, I'll write it like this:
In MSG byte 5.
Bit 4 enabled = GRA - PR-8T2/8T6.
Bit 6 activated = Adaptive GRA with ACC - PR-8T5.
Bit 5 and 6 activated = Adaptive GRA with ACC and Front Assist (PR-8T3/8T8)
Here's the translation:
"For example, if only GRA were used for the new encoding in the MSG, it would be..."
0125001223240D080000000000000000000000000000000
In the STG 19 module, the APK "SFT271921-MAS06614-Control unit for multifunction steering wheel variant" should be set to GRA-High.
CUBE
dieselschrauber and brezelmann01 likes this.
Post10-07-2022, 11:45    Subject: Retrofitting GRA for VW T-Cross Quote
I just realized I misspelled something.
Byte 5, bit 4 would be the AHK (Application Hook), but the encoding was still correct.
Here is the correction:
In MSG byte 5.
Bit 5 activated = GRA - PR-8T2/8T6.
sharanwolf
Post02-04-2023, 11:29    Subject: Activate ACC retroactively Quote
Hello Cube,
Thank you for the information.
I have a T-Cross here that came with Front Assist from the factory.
So, only the speed limiter is activated.
It has the MFL pro installed.
Unfortunately, all the bits in the MSG/brake control module are undocumented.
I entered the value "24" for you into the MSG. As a result, the limiter symbol disappeared from the MFA, and the ACC symbol appeared, but there are errors in the brake control module and in module 13.
What else do I need to recode in these two devices?
I've now added a scan of the previous page.
Does anyone know the settings in the brake control unit and the "13er" (likely referring to a specific module or system)?
Greetings.
Log-xxx-15849km.txt
 File name:  Log-xxx-15849km.txt
 File size:  10.76 KB
 Downloaded:  429 times
CUBE
sharanwolf likes this.
Post02-04-2023, 19:49    Subject: Retrofitting GRA for VW T-Cross Quote
Hi, you need to enter "64" in the MSG field on your end. The 24 was the example without ACC for the above.
0111001223640D080000000000000000000000000000000
ADpoppe
Post09-05-2025, 11:30    Subject: Upgrade GRA Quote
Hi... I always get errors in the MSG, no matter which coding I choose.
Can anyone help?
Thank you.
Log-HP PE 624-WVGZZZC1ZMY002955-65209km.txt
 File name:  Log-HP PE 624-WVGZZZC1ZMY002955-65209km.txt
 File size:  28.77 KB
 Downloaded:  177 times
Post09-05-2025, 17:50    Subject: Retrofitting GRA for VW T-Cross Quote
What does LCode say?
ADpoppe
Post11-05-2025, 12:47    Subject: Means? Quote
Is there anything else you need? It's sometimes offered, supposedly without requiring any hardware.
Post21-05-2025, 10:30    Subject: Retrofitting GRA for VW T-Cross Quote
Nash
1997 Volkswagen Passat
Post21-05-2025, 15:48    Subject: GRA Audi Q2 Quote
I'm just chiming in here. This week, I retrofitted a cruise control system to my Q2, which is a model from December 2021. The SVM codes were provided by the seller.
My local Audi dealer wasn't thrilled to just be allowed to/required to make the adjustment. That means he rejected it outright.
Audi Q2.
MKB: DNNA
PR: 8T9
The vehicle only has a speed limiter.
The LOG is attached.
Thank you very much.
Log-WAUZZZGA1NA015489-40548km-Baier.txt
 File name:  Log-WAUZZZGA1NA015489-40548km-Baier.txt
 File size:  21.17 KB
 Downloaded:  231 times
AFN mit aktuell 546.465km auf der Uhr
No new posts Retrofitting a tow hitch on a Passat 3C, model year 2007 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aftermarket Leather Steering Wheel with Airbag Troubleshooting & Guides
No new posts Speed Control Retrofit Seat Ibiza / Polo Troubleshooting & Guides
No new posts TDI B4: Upgrade GRA (1992) Diesel Engine Technology
No new posts Retrofit BT for 9ZF Transmission Transmission, Chassis, Body & Interior
No new posts VW: Retrofitting LDA (Local Differential Analyzer) Diesel Engine Technology
No new posts Retrofit AHK for Galaxy 1999: Installation Guide On-Board Diagnostics (OBD)
