Diesel Filter Housing Connector for VW Golf V 1.9 TDI
JO_Golf5-TDI
Post04-02-2018, 16:57    Subject: Diesel Filter Housing Connector for VW Golf V 1.9 TDI Quote
Can someone tell me which connection on the diesel filter housing corresponds to which line? (Fuel tank inlet / Fuel tank outlet / Engine inlet / Engine outlet) (See picture).
I couldn't find anything about this enclosure in the forum.
Thank you in advance.
 File size:  2.01 MB
 Viewed:  22690 times
Translated on 07-09-2026, 4:02.
dieselschrauber likes this.
Post05-02-2018, 12:39    Subject: Diesel Filter Housing Connector for VW Golf V 1.9 TDI Quote
There was already a post about this with pictures. The conclusion at that time was that there were two different versions.
A Google search for "diesel mechanic diesel filter connections" provides the pinout diagram for one type of connector in the first result.
Translated on 07-09-2026, 4:03.
JO_Golf5-TDI
Post05-02-2018, 19:18    Subject: Diesel Filter Housing Connector for VW Golf V 1.9 TDI Quote
Thank you in advance for the answer, Guste100.
guste100 wrote:
There was already a post with pictures about this before. The conclusion at that time was that there are two different variants.
The Google search for "diesel mechanic diesel filter connections" provides the pinout of one connector in the first link.
I already found this post, but since my connections are not the same as the ones shown in the filter, I thought I would ask again.
If I follow the mapping from the thread mentioned above, the connections would be:
1 = Supply line to tank.
2 = Return line, tank.
3 = Motor return line.
4 = Engine coolant inlet.
Do you think that's correct?
Translated on 07-09-2026, 4:04.
Karma: +1344 / -0   Thank you, like it!
Post05-02-2018, 21:46    Subject: Diesel Filter Housing Connector for VW Golf V 1.9 TDI Quote
Suggestion: RLF (roof rack) or a similar product suitable for the vehicle.
It's always a good idea to have at least some basic documentation before you start working on something.
Translated on 07-09-2026, 4:06.
JO_Golf5-TDI
Post12-02-2018, 9:08    Subject: Diesel Filter Housing Connector for VW Golf V 1.9 TDI Quote
Hi Herbert,
"Thank you, that was the right guide, I replaced it and the car is running like new again."
dosenwerni
Post17-06-2023, 12:02    Subject: Connections: Important Information & Details Quote
I checked the system and found that the motor's forward and reverse functions were not working correctly.
Correct, as shown in the attached photo.
Perhaps this will help someone else.
Translated on 07-09-2026, 4:07.
Post18-06-2023, 7:10    Subject: Connections: Important Information Quote
dosenwerni wrote:
I was here and noticed that the motor's forward and reverse functions were not working correctly.
Correct, as shown in the attached image.
Maybe it will help someone again.
Arrows without any text explaining what they are or which vehicle they are for, along with an image that you don't have the rights to, are of no help to anyone!
As mentioned before, there are several variations:
Translated on 07-09-2026, 4:08.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Gaspoti Connectors: Types & Compatibility Diesel Engine Technology
No new posts Differential Pressure Sensor: How Many Ports? Diesel Engine Technology
No new posts Tacho Golf 3 an 6-GangGetriebe aus Golf 4-> kein Signal ? Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
