Windshield Washer Hose Repair Kit
vag-driver
Post25-08-2023, 22:27    Subject: Windshield Washer Hose Repair Kit Quote
"On my Sharan 7N, the hose leading to the windshield washer nozzles is broken near the hood hinge. There are repair kits available for this on eBay." In the past, I have already used a similar type of seal on a T5, and it didn't last for more than 2 years.
Is there a reliable and durable alternative to fix the damaged area? Ideally, I would prefer to switch back to the types of hoses that were available for the Golf 2/3 and Polo 6N generations. They should last at least 30 years...
Andreas
Translated on 03-07-2026, 22:00.
Karma: +1100 / -0   Thank you, like it!
dieselschrauber and E30_V8 likes this.
Post26-08-2023, 10:43    Subject: Windshield Washer Hose Repair Kit Quote
The corrugated tubes are complete garbage! Already too stiff, and the alcohol content in the windshield de-icer causes further embrittlement, leading to its final disintegration.
Here's how I solved it for Uwe's high-performance T5.2: I measured the outer diameter of the corrugated tube and bought aquarium tubing with a matching inner diameter. I applied aquarium sealant to a 1 cm section at each end of the corrugated tube and then slid the larger aquarium tubing over it. The advantage is that the inner cross-section doesn't decrease, and the flow rate isn't reduced. However, I cut out a larger section of the corrugated tube and replaced it with the aquarium tubing. I didn't want the corrugated tube in the bending area, and the glued areas should also be outside the mechanically stressed area. This creation has now lasted through two winters and three summers.
Initially, Uwe tried to push a thinner hose into the corrugated hose and secure the "artwork" with hose clamps. The cross-section decreased, the pressure in front of the constriction increased, and eventually, his artwork burst apart.
Translated on 03-07-2026, 22:02.
vag-driver
dieselschrauber likes this.
Post27-08-2023, 15:04    Subject: Windshield Washer Hose Repair Kit Quote
"That's putting it mildly; it's utter nonsense."
"To my knowledge, aquarium hoses are made of PVC, which is why I'm surprised by their durability. PVC is prone to hardening and, as a result, becoming brittle and breaking."
Andreas
Translated on 03-07-2026, 22:04.
vag-driver
Post28-08-2023, 15:46    Subject: Windshield Washer Hose Repair Kit Quote
I have now ordered a PVC hose after consulting with an online retailer, and I will seal it with PVC glue.
Hopefully, I will be able to share some positive experiences.
Andreas
dieselschrauber, Herbert and E30_V8 likes this.
Post29-08-2023, 8:23    Subject: Windshield Washer Hose Repair Kit Quote
The original corrugated hose in 6x0.75mm costs approximately €20 for 1 meter. It lasts (at least in my case) for about ten years. The parts from online marketplaces might be of lower quality. I wouldn't spend too much time tinkering with those; I would simply buy a meter of the original hose and install it. If it lasts another ten years, that would be more than enough for me.
If you're not getting a good result, I would separate the moving area from the fixed area. Then, use a waterproof heat-shrink tubing (with adhesive on the inside) to connect the hoses "end-to-end."
Translated on 03-07-2026, 22:05.
vag-driver
Post29-08-2023, 11:43    Subject: Windshield Washer Hose Repair Kit Quote
My corrugated pipe has an outer diameter of 7.2 mm. That's why I ordered a transparent 7 mm PVC hose, which I will glue accordingly. These O-ring repair kits on eBay don't last very long. At least, that was the case with the T5 that I refurbished about 2 years ago.
Andreas
Translated on 03-07-2026, 22:06.
Post29-08-2023, 12:49    Subject: Windshield Washer Hose Repair Kit Quote
The relevant question is, what do the 7.2 mm refer to? The original corrugated pipe with a size of 6x0.75 is used in many models, especially where flexibility is required.
For the Sharan 7N models from 2014 onwards, it's the same part number as for the A4 8K models from 2014. It's been almost ten years for me.
Translated on 03-07-2026, 22:07.
vag-driver
Post29-08-2023, 12:54    Subject: Windshield Washer Hose Repair Kit Quote
It's broken on mine, for some reason... Maybe someone messed with it when the windshield was replaced. I can't think of any other cause.
The outer circumference of my corrugated pipe is 7.2 mm. These are the facts.
Andreas
Translated on 03-07-2026, 22:08.
Post29-08-2023, 13:04    Subject: Windshield Washer Hose Repair Kit Quote
The outer circumference of my corrugated hose is 7.2 mm. Those are the facts.
Then, go to a VW parts department and have them look up the correct part number and hose designation for you. It is likely 1J0 955 751 D, 6 x 0.75 mm icon_idea.gif. The dimensions refer to the end. Suggestion for diameter: inner.
Translated on 03-07-2026, 22:09.
vag-driver
Post07-09-2023, 18:40    Subject: Windshield Washer Hose Repair Kit Quote
The attempt to slip a PVC hose over it and glue it in place didn't work. Then my neighbor brought over his Herth+Buss connector assortment. We glued the 4mm connector in place using super glue. Hopefully, it will last a very long time.
Andreas
No new posts Turbocharger Boost Hose: Connection & Oil Issues Diesel Engine Technology
No new posts Oil in Coolant Hose: Causes & Fixes Diesel Engine Technology
No new posts Burst Hose: Causes, Repair & Prevention Transmission, Chassis, Body & Interior
No new posts Air Filter Hose: Replacement & Installation Guide Diesel Engine Technology
