Golf 5 Steering Sensor (G269) Replacement
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
abicim
Post23-01-2024, 0:07    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Hello everyone,
My Volkswagen Golf 5, manufactured in October 2003 (chassis number: WVWZZZ1KZ4W003442).
After replacing the springs and shock absorbers, the vehicle is displaying an error code with a red steering wheel symbol.
"One error found:"
00573 - Steering torque sensor (G269).
012 - Electrical fault in the circuit.
Environmental conditions:
Mileage: 6400 km
Torque: -6.0 Nm.
I have tried to calibrate the steering angle sensor multiple times using VCDS, but unfortunately without success; the error persists, and the steering is very stiff.
All fuses have been checked and are in good working order.
I can also access the control unit 44 (steering assist) and view its values.
Unfortunately, I'm stuck and would be very grateful for any help you can offer.
Translated on 25-07-2026, 1:33.
Post23-01-2024, 19:37    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Steering angle sensor ≠ steering torque.
According to my information, the torque sensor is located in the steering gearbox.
Please provide the complete car scan data.
Translated on 25-07-2026, 1:35.
abicim
Post24-01-2024, 12:51    Subject: Car Scan: Diagnostics & Repair Services Quote
Wednesday, January 24, 2024, 11:46:43:60913
VCDS - A VAG/VAS emulator based on Windows - runs on Windows 11 x64.
VCDS version: RKS 23.3.1.0 HEX-NET CB: 0.4643.4
Data as of: 20230601 DS346.2
http://shop.dieselschrauber.org/en
Vehicle Identification Number (VIN): WVWZZZ1KZ4W003442 License plate:
Mileage: 186,430 km. Repair order: Volkswagen Golf 5.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
Vehicle Identification Number (VIN): WVWZZZ1KZ4W003442. Mileage: 186,430 km.
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit - Status: OK.
09-Central Electrical System -- Status: OK.
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
42-door electric driver -- Status: OK 0000
Steering assist - Status: Error 0010.
46-Comfort System -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
56-Radio -- Status: Error 0010.
62- Door, electric, left and right -- Status: OK 0000
72- Door, electric, high, right side -- Status: OK 0000
77-Phone -- Status: Error 0010.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Feld und lÀsst das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine Control Module
Label file: DRV\03G-906-016-BKD.clb
Part number SW: 03G 906 016 AN, Hardware number: 028 101 147 7.
Component: R4 2.0L EDC 0000SG 5402.
Revision: 12345678 Serial Number: VWZ7Z0C7961334
Encoding: 0000072
Operating number: WSC 00000 028 00001
VCID: 6FAE35827E70FDEB22-803A
VINID: 9E69EAAAA05BA849C00031040891A3697E
No error codes found.
Readiness: 0 0 0 1 1
Address 03: Brake Electronics
Label file: DRV\1K0-907-379-MK60-F.clb
Part number: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Encoding: 0023170
Operating number: WSC 01279 785 00200
VCID: 3A38D4D675B26843C5-806E
Address 08: Climate Control/Heating. Label file: DRV\1K0-907-044.lbl
Part number: 1K0 907 044 L
Component: Climatronic PQ35 061 0201
Operating number: WSC 00000 000 00000
VCID: 302CF6FEA3CEA2137B-8064
Address 09: Central Electronics; Label file: .DRV\3C0-937-049-23-H.lbl
Part number SW: 1K0 937 049 J. Part number HW: 1K0 937 049 J*.
Component: Onboard network module SG 1.0 H27 0601.
Revision: 00027000 Serial Number: 00000000071767
Encoding: 01898F2600041000001400001400000000
Operating number: WSC 12345 123 12345
VCID: 3620C0E641AA8C2321-8062
Subsystem 1 - Component: LIN Slave Device Error 01.
Address 15: Airbag
Label file: DRV\1K0-909-605.lbl
Part number SW: 1K0 909 605 A, Hardware: 1K0 909 605 A.
Part number: 06 AIRBAG VW8 021 0500.
Revision: 03021000 Serial Number: 0033FD022S7U
Encoding: 0012342
Operating number: WSC 01268 785 00200
VCID: 2A18E4968512D8C3B5-807E
Subsystem 1 - Serial Number: 6332MSME5D760E00
Subsystem 2 - Serial number: 6342MSME1F740E00.
Subsystem 3 - Serial number: 6351HSME39071300.
Subsystem 4 - Serial number: 6361HSME4F021A00.
Address 16: Steering wheel electronics
Label file: DRV\1K0-953-549-MY8.lbl
Part number SW: 1K0 953 549 A, Hardware part number: 1K0 953 549 A.
Component: Steering column module 009 0030.
Coding: 0000012
Address 17: Control panel module
Label file: DRV\1K0-920-xxx-17.lbl
Part number: 1K0 920 860 F
Component: COMBINATION INSTRUMENT VDD 1220
Encoding: 0001101
Operating number: WSC 11111 111 11111
VCID: 2B16E1928AE8C1CB4E-807E
Address 19: Diagnostic interface (J533)
Label file: .DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 M, HW: 1K0 907 951.
Component: J533 Gateway H42 1623.
Revision: H42 Serial Number: 040512F2000760
Encoding: 350002
Operating number: WSC 01357 011 00200
VCID: 3A38D4D6B5B26843C5-806E
Address 25: Immobilizer
Label file: DRV\1K0-920-xxx-25.clb
Component: IMMO 1220
Address 42: Door electric driver
Label file: DRV\1K0-959-701-MIN1.lbl
Part number: 1K0 959 701 E
Component: Door control unit 09 0102.
Coding: 0000052
Address 44: Steering Assist
Label file: DRV\1Kx-909-143-GEN1.clb
Part number: 1K1 909 143 L
Component: EPS_ZFLS, Class 2, Size 0402.
VCID: 3326F9F252D8990B06-8066
Two error codes found:
02546 - Steering end stop.
005 - No or incorrect initial setup/adaptation - Occasional.
Mileage: 6400 km
Temperature: 19.0°C
Voltage: 14.10 V
Voltage: 13.80 V
Mileage: 6400 km
Torque: -6.0 Nm
Address 46: Comfort System; Label file: .DRV\1K0-959-433-MIN.clb
Part number: 1K0 959 433 C.
Component: KSG 0201
Encoding: 00E802087F2D8404084F0100
Address 52: Door electric, passenger side. Label file: DRV\1K0-959-702-MIN1.lbl
Part number: 1K0 959 702 E
Coding: 0000052
VCID: 312AF3FAA8C4AB1B74-8064
Address 56: Radio (J503) Label file: .DRV\5M0-035-1xx-56.clb
Part number SW: 6RD 035 187 B, Hardware part number: 6RD 035 187 B.
Component: Radio 541 5814
Revision: -------- Serial Number: VWZZZ4H6290655
Encoding: 16000400040005
Operating number: WSC 127395 840 08317.
VCID: 46C0B026F14A1CA3B1-8012
01317 - Control unit in the instrument panel carrier (J285).
004 - No signal/communication.
Error status: 01100100
Error priority: 6
Error frequency: 1.
Lost Count: 197
Mileage: 186,437 km
Time: 0.
Date: 2000.00.00
Time: 00:04:56
00856 - Antenna; for the radio.
011 - Interruption - Occasional/Sporadic.
Error status: 00101011
Error priority: 5
Error frequency: 1.
Lost Count: 197
Mileage: 186,437 km
Time: 0.
Date: 2000.00.00
Time: 00:07:13
Address 62: Door electrics, left and right. Label file: DRV\1K0-959-703-GEN1.lbl
Part number: 1K0 959 703 C.
Component: Door control unit 05 0108.
Encoding: 0000016
Address 72: Door electric strike, high, right.
Label file: DRV\1K0-959-704-GEN1.lbl
Part number: 1K0 959 704 C.
Encoding: 0000016
Address 77: Telephone Label file: DRV\1K0-035-729-UNI.lbl
Part number: 1K0 035 729 B
Component: CIB PAH HW 112 SW 0194.
Operating Number: WSC 00001 000 00000
VCID: 281C1E9E9B1EEAD3A3-807C
"One error found:"
01530 - Mute radio.
009 - Short circuit to ground / Ground fault.
End -------- (Duration: 01:08, Battery voltage start/end: 12.5V/12.5V) ---------
Translated on 25-07-2026, 2:05.
RĂŒdi
dieselschrauber likes this.
Post24-01-2024, 19:01    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Be prepared to replace the steering rack; it's not a major job. You can remove it along with the axle in a maximum of 2-3 hours.
Translated on 25-07-2026, 2:42.
abicim
Post24-01-2024, 19:17    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Since I had assumed that was the case, I disassembled it today and will order a new one. I have a couple of questions about that:
- I have installed the first generation, and only the second and third generations are available for purchase. If I were to install a second-generation unit, what should I be aware of, besides needing to obtain a wiring harness?
- Do I need to use VCDS to calibrate the transmission or perform a similar procedure, other than calibrating the steering angle sensor?
Translated on 25-07-2026, 2:43.
RĂŒdi
Post24-01-2024, 19:53    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Make sure to use the exact part with the same part number as the one that's currently installed.
abicim
Post24-01-2024, 20:25    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
I found a refurbished one that includes my part number.
Is a software update or similar required, or is it simply plug and play, and do I just need to calibrate the steering angle sensor (G85)?
Translated on 25-07-2026, 2:44.
E30_V8 likes this.
Post24-01-2024, 21:03    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Is a software update or something similar required, or is it simply plug & play, and do I just need to calibrate the steering angle sensor G85?
Contains?
Okay, I'm ready. Please provide the German text you want me to translate into English.
Translated on 25-07-2026, 2:45.
abicim
Post24-01-2024, 21:25    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Thank you for the reminder; I just checked again and it is included.
1K1423051AN
Translated on 25-07-2026, 2:46.
abicim
Post24-01-2024, 22:36    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
I read something about adjusting the characteristic curve (using VCDS - adaptation channel), but I don't know what value I should set it to.
Post25-01-2024, 22:16    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Check the old ECU?
Translated on 25-07-2026, 2:47.
abicim
Post25-01-2024, 22:26    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
According to the scan, for the older Gen 1 steering rack, there are two options.
Part number: 1K1 909 143 L.
Component: EPS_ZFLS Size 2 0402.
The new Gen 2 steering system is supposed to be loaded via VCP, but how do I find the correct calibration curve to upload?
Translated on 25-07-2026, 2:48.
Post26-01-2024, 11:51    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
abicim wrote:
According to the scan, for the older Gen 1 steering rack, there are two:
Address 44: Steering assist
With the new Gen 2 steering system, it is supposed to be loaded via VCP, but now, how do I find the correct calibration curve to upload?
It doesn't sound like the "adaptation" function to me; rather, it sounds like writing a memory area to flash or EEPROM.
What options are available in the "Adjustment" function of VCDS?
What does the automatic scan show for the new steering rack?
Translated on 25-07-2026, 2:50.
abicim
Post02-02-2024, 13:27    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
The new steering rack (Gen 2) has now been installed and is working correctly. The steering angle sensor (G85) was calibrated, and then I went to have the alignment adjusted.
The auto-scan indicates that part number KL 077 is being used.
Here's the new car scan:
Wednesday, January 31, 2024, 21:43:57:60913
VCDS - A Windows-based VAG/VAS emulator that runs on Windows 10 x64.
VCDS version: RKS 23.11.0.1 HEX-NET CB: 0.4643.4
Data as of: 20240115 DS351.0
Mileage: 186,440 km. Repair order: following replacement of the steering gear.
Vehicle Identification Number (VIN): WVWZZZ1KZ4W003442. Mileage: 186,440 km.
Steering assist - Status: OK 0000.
Encoding: 0000072
VCID: 6FAE35827E70FDE92B-803A
Readiness: 0 0 0 0 1
Encoding: 0023170
VCID: 3A38D4D675B26841CC-806E
VCID: 302CF6FEA3CEA21172-8064
Revision: 00027000 Serial number: 00000000071767
VCID: 3620C0E641AA8C2128-8062
Address 15: Airbag
Encoding: 0012342
VCID: 2A18E4968512D8C1BC-807E
Coding: 0000012
Encoding: 0001101
VCID: 2B16E1928AE8C1C947-807E
Encoding: 350002
VCID: 3A38D4D6B5B26841CC-806E
Coding: 0000052
Label file: DRV\1Kx-909-144-G2V3.clb
Part number: 1K1 909 144 L
Component: EPS_ZFLS Class 077 H07 1806.
Operating number: WSC 06402 785 00200
VCID: 3424FAEE57D69E3116-8060
Component: KSG 0201
Coding: 0000052
VCID: 312AF3FAA8C4AB197D-8064
VCID: 46C0B026F14A1CA1B8-8012
Error priority: 6
Error frequency: 1.
Lost Count: 198
Mileage: 186,447 km
Time: 0.
Date: 2000.00.00
Time: 21:34:46
011 - Interruption.
Error status: 01101011
Error priority: 5
Error frequency: 1.
Lost Count: 198
Mileage: 186,447 km
Time: 0.
Date: 2000.00.00
Time: 21:34:47
Encoding: 0000016
Encoding: 0000016
VCID: 281C1E9E9B1EEAD1AA-807C
"One error found:"
01530 - Mute radio.
End -------- (Duration: 01:00, Battery voltage start/end: 14.2V/14.2V) ---------
Translated on 25-07-2026, 3:19.
Post02-02-2024, 20:48    Subject: Golf 5 Steering Sensor (G269) Replacement Quote
Thank you for the feedback icon_smile_thumb_up.gif.
Translated on 25-07-2026, 3:56.
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Coolant Temperature Sensor for VW Golf III Diesel Engine Technology
No new posts Wo ist beim Golf IV der Geber fĂŒr die LĂ€ngsbeschleunigung? On-Board Diagnostics (OBD)
No new posts ESP error sensor for yaw rate, Golf IV (G202) On-Board Diagnostics (OBD)
No new posts was fĂŒr ein Geber ist das? Diesel Engine Technology
