I replaced the throttle body on an A5 V6; the plastic teeth on the old one were worn out.
"It was originally a VDO part, but I installed a Pierburg one, and it also works with the actuator diagnostics."
Error rate is 0.00 / minute.
I tested the cables under load (H4 lamp) and they are in good condition.
What bothers me are the values for "Throttle Offset Closed" and "Throttle Offset Open," as they also fluctuate while the system is running (as seen in the log file).
There are no built-in options for adaptation in the default settings.
The new DK might have a bug.
| Description: |
 Download |
| File name: |
DK.xlsx |
| File size: |
17.61 KB |
| Downloaded: |
196 times |
| Description: |
 Download |
| File name: |
Log-WAUZZZ8T68A043356.txt |
| File size: |
3.28 KB |
| Downloaded: |
658 times |
VCDS
Translated on 09-07-2026, 10:36.
