High beam assist matrix error
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
PAOKGREEK
Post23-01-2024, 8:39    Subject: High beam assist matrix error Quote
Hello and good morning.
I have a question.
I tried to code the Matrix LED headlights onto my T-Roc facelift with the 1.5-liter gasoline engine.
Since I had these 3 errors, I reverted everything back to the previous version.
But they stayed.
Adjusting the headlight alignment using the STG 9 did not resolve the issue.
The "032 Basic Setting" error message disappeared only after performing the basic setting in the 5F control unit.
The first two error codes are still present.
Can only VW perform this basic adjustment?
Should I just recode Matrix and then take it to VW?
Greetings.
Chris.
3 error codes found:
5350720 - Matrix headlight, left side.
C1175 54 [137] - no default setting.
Warning light ON - confirmed - checked since last reset.
Environmental conditions:
Error status: 00000001
Error priority: 2
Error frequency: 1.
Lost count: 15
5350976 - Matrix high beam, right side.
C1176 54 [137] - no baseline established.
Error priority: 2
Error frequency: 1.
Lost count: 15
0032 - Headlights
C107E 54 [137] - no default setting.
Error priority: 2
Error frequency: 1.
Lost count: 15
PAOKGREEK
dieselschrauber and Turbinchen likes this.
Post24-02-2024, 10:36    Subject: High beam assist matrix error Quote
Hi, even though someone helped me with the programming, I still had to take it to a workshop to perform the basic configuration of the LED matrix.
This can only be done with the tester.
After that, the matrix and data bus errors were gone.
Test drive in the dark.
Matrix is working icon_smile.gif.
Thank you again icon_smile.gif.
Is it possible to unlock the matrix function through coding on headlights that are labeled as "IQ Light" and referred to as "LED Plus" headlights? icon_smile.gif
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High Beam Error: Coding Issues & Fixes On-Board Diagnostics (OBD)
No new posts High beam on -> Fog lights off? Transmission, Chassis, Body & Interior
No new posts High beam permanently activated, VW Caddy Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3c, front fog light, left, long-range light Electrical Systems, Vehicle Electronics, Multimedia
