I can't access the service mode of the Climatronic!
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
alex-on-line.de
Post09-11-2003, 15:34    Subject: I can't access the service mode of the Climatronic! Quote
I have a Volkswagen Golf III manufactured in 1995.
What keyboard shortcut does it use?
Translated on 18-07-2026, 5:35.
alex-on-line.de
Post09-11-2003, 18:08    Subject: I can't access the service mode of the Climatronic! Quote
Does anyone know?
Translated on 18-07-2026, 5:36.
WarLord
Post09-11-2003, 18:31    Subject: I can't access the service mode of the Climatronic! Quote
There just aren't that many people online in the forum right now.
Best regards, WarLord.
Post10-11-2003, 21:01    Subject: I can't access the service mode of the Climatronic! Quote
Okay, so I'm going to share my Google search results with you now. As I suggested, try searching there. You'll likely be directed to the "Passat 35i" forum quite quickly.
Your Climatronic system likely has 3 diagnostic functions.
1. Error memory: Turn the ignition on, set the climate control to automatic mode, and press the OFF and TEMP+ buttons simultaneously for 3 seconds. Continue pressing the TEMP+ button to cycle through the error codes, which you should note down. Keep pressing TEMP+ until "0000" is displayed. When "0000" is shown, press and hold the OFF button for 3 seconds until "4444" is displayed; this will clear all errors from the memory.
(Honestly, who comes up with this kind of nonsense?)
If you need more information, check their forum or contact me, and I'll email you everything.
Translated on 18-07-2026, 5:37.
alex-on-line.de
Post15-11-2003, 19:24    Subject: I can't access the service mode of the Climatronic! Quote
Thank you for your efforts.
Unfortunately, I don't have an 'Off' button, but I do have the 'ECON' button.
It would still be nice if you could send me something sometime.
Translated on 18-07-2026, 5:39.
Post15-11-2003, 22:05    Subject: I can't access the service mode of the Climatronic! Quote
Then I can't help you anymore. I'm running out of ideas. But here's a tip: Press all the keys in pairs and triplets for three seconds each. Skip unlikely combinations (for now). By that, I mean pressing "Temp" simultaneously with "Temp+" and so on.
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts G3 AFN Power Loss: Troubleshooting Guide Diesel Engine Technology
No new posts Motorsteuergerät Messwertblöcke, ich komme nicht rein On-Board Diagnostics (OBD)
No new posts Climatronic coding not changeable? On-Board Diagnostics (OBD)
No new posts Passat: Climatronic Not Working / ABS Issues Transmission, Chassis, Body & Interior
