BMR intake manifold swirl flaps repeatedly leak
phgraf
Avatar-phgraf
Karma: +14 / -0   Thank you, like it!
dieselschrauber likes this.
Post08-08-2024, 12:56    Subject: BMR intake manifold swirl flaps repeatedly leak Quote
I'm experiencing the problem again where the intake manifold is leaking and causing a loss of boost pressure.
The outlet is located where the swirl flap's wave exits and connects to the actuation linkage. That's why I've already replaced the intake manifold module once, but I don't want to have to do that every three years.
Therefore, the 1. Question: Does anyone know a simple way to fix it myself?
Alternatively, I would completely remove the swirl flaps, which should be relatively straightforward since there is no position sensor for them.
Therefore, the 2. Question: Does anyone have a better idea for plugging those two holes? I was thinking of using one screw each with a little bit of silicone sealant.
Translated on 04-07-2026, 4:33.
3bAFN
Karma: +33 / -0   Thank you, like it!
dieselschrauber, Turbinchen and phgraf likes this.
Post09-08-2024, 9:58    Subject: BMR intake manifold swirl flaps repeatedly leak Quote
Hi, you can also simply use an intake manifold from a BKD engine. There were also some made without swirl flaps, and those were made of aluminum.
Sören
Translated on 04-07-2026, 4:35.
phgraf
Avatar-phgraf
Post16-08-2024, 22:13    Subject: BMR intake manifold swirl flaps repeatedly leak Quote
Thanks for the tip, I just installed it and it fits perfectly.
Valuable information!
It will become clear tomorrow afternoon whether this has also resolved my persistent issue with low charging speed.
No new posts Document A6 4B, Fog lights leaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T6 Windshield Washer Fluid Leaking, Washer Fluid Tank Dam... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Passat 3B2 Achsmanschette undicht Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust manifold repeatedly leaking Diesel Engine Technology
No new posts Wheel Bearing Problems VW Golf 6? Transmission, Chassis, Body & Interior
No new posts BMW X3 swirl flaps Transmission, Chassis, Body & Interior
No new posts Removing Swirl Valves: Experience and Tips Diesel Engine Technology
