DSG Lebensdauer und Haltbarkeit | Posts 16+
Go to page: Previous  1, 2
Karma: +805 / -0   Thank you, like it!
Post06-12-2020, 21:24    Subject: Quote
A friend's T6 had its DSG fail around 100,000 km. Driving was no longer possible; the gear would repeatedly slip out of gear – no forward motion. icon_confused.gif
Knox92
Karma: +22 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-09-2024, 19:39    Subject: Quote
DSG Type DQ200
- Vehicle Model VW Touran 1T
- Mileage 209,000 km
- Chiptuning No
- Possible damage - The "144,000" reading blinks while driving.
The thread on the mechatronic unit where the pressure sensor is located has cracked, so a new mechatronic unit is required.
There is also a repair kit with a threaded insert and a new pressure accumulator. Since the repair, there have been no more problems, even though the Touran is regularly used with a trailer or a caravan.
The problem, however, is quite well-known.
VCDS, VCP, Fahrzeugdoku & Anleitungen vorhanden
________________________________
Fahrzeuge:
- Golf 5 1.4 BUD 2009
- Touran 1T 1.9 BLS 2011
Knox92
dieselschrauber, Hutfahrer and Autoservice likes this.
Post15-09-2024, 21:42    Subject: Quote
DSG Type S Tronic 5B1
- Vehicle Model Audi A6 4G2
- Mileage 192,000
- No Chiptuning
- Possible damage Gearbox issues during operation
Fault storage entry: Oil temperature too high.
Installed power supplies and valves - Problem solved. A good tip: When installing, make sure the valves are in the correct position so that they can all function properly - I checked this with an endoscope camera.
But it is relatively "simple" if the mechatronics are developed, or almost self-explanatory. It is important that the printed circuit boards can only be installed once, so they should not be reused, as this would no longer guarantee the contact force, which could lead to subsequent errors.
 File size:  750.22 KB
 Viewed:  880 times
 File size:  807.3 KB
 Viewed:  821 times
 File size:  824.85 KB
 Viewed:  815 times
 File size:  845.65 KB
 Viewed:  830 times
Fahrzeuge:
No new posts 1.8T Engine: Reliability and Durability Diesel Engine Technology
No new posts H7 Bulb Lifespan: How Long Do They Last? Diesel Engine Technology
No new posts Fuel Injector Lifespan: How Long Do They Last? Diesel Engine Technology
No new posts Durable PDEs: Longevity and Reliability Diesel Engine Technology
