Wastegate actuator for turbocharger stuck. Solved (Solution)
Schmierpfote
Karma: +21 / -0   Thank you, like it!
dieselschrauber likes this.
Post09-12-2024, 17:48    Subject: Wastegate actuator for turbocharger stuck. Solved Quote
Hello everyone,
The throttle body on the T6 110kW engine is increasingly prone to sticking at 2500 RPM.
I installed a new pressure transducer for the TL system, and now it can reach its full range without going into emergency mode.
It lasted almost 8 years and 315,000 kilometers.
I'm still having a problem with the NOx sensors before and after the catalytic converter.
Pairing is not performed by the MSG. "The reading shows as inactive."
How can she be trained?
Best regards, Wolfgang.
Back to top Profile PM Email
Ratings - Wastegate actuator for turbocharger stuck. Solved
No new posts Document A2 8Z0 KJ 2002, Steering lock jammed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J documentation up to 05/99, sunroof stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P00AF: Turbocharger Malfunction - Causes & Fixes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger: Which Brand is Best? Diesel Engine Technology
No new posts AFN VTG 96: Stuck Valve - Troubleshooting:( Diesel Engine Technology
No new posts DSG Shift Knob Stuck: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts VTG gets stuck, then releases again. Upload
