DQ351 Calibration: How-To Guide
Asima
Post28-07-2025, 17:25    Subject: DQ351 Calibration: How-To Guide Quote
Hello.
I'm just not always satisfied with the shifting performance of the DQ351 transmission in my now 4-year-old Audi S3.
A software update has already been performed, and I have tried to calibrate the system multiple times using VCDS (the latest version, HEX-V2).
The process of clearing the learning values cannot be started in VCDS. While the calibration process can be initiated, it stops after a few cycles and noises. I kept my foot on the brake, didn't accelerate, and the transmission oil temperature was also within the specified range. Of course, I also tried it outside, with the same result: it stops, and the sub-status shows "16".
What's the problem?
Do I need to go to the workshop?
Thank you very much.
 File size:  28.52 KB
 Viewed:  1112 times
Translated on 01-09-2026, 20:15.
Karma: +805 / -0   Thank you, like it!
Post30-07-2025, 16:47    Subject: DQ351 Calibration: How-To Guide Quote
Hi Autoscan?
Points in
were they followed?
Translated on 01-09-2026, 20:16.
Asima
Post02-08-2025, 10:40    Subject: DQ351 Calibration: How-To Guide Quote
Hello Rainer,
I followed these instructions.
...link elsewhere...
Translated on 01-09-2026, 20:17.
Post02-08-2025, 11:15    Subject: DQ351 Calibration: How-To Guide Quote
Nice, but that wasn't my question...
No new posts Injector calibration with VCDS Troubleshooting & Guides
No new posts Automatic LMM Calibration: Gremlin Solution Diesel Engine Technology
