Short Circuit Error Code Explained
ARS326
Post29-08-2025, 19:13    Subject: Short Circuit Error Code Explained Quote
The error codes repeatedly provide the names.
"Interruption/Short circuit after positive voltage."
or
"Short circuit to ground"
"aus."
Can someone briefly explain what's specifically involved here, or what the difference is between the two?
Translated on 28-08-2026, 14:54.
Post30-08-2025, 18:58    Subject: Short Circuit Error Code Explained Quote
It depends on the specific circuit configuration, so a circuit diagram is very helpful in each case to determine what is going wrong.
In the first case, the potential at the corresponding measurement point is +12V or there is no signal; in the latter case, it is at ground potential.
Open circuit/Short circuit to positive: Often caused by corroded or broken wires, loose connectors, or damaged insulation that creates a short circuit to the positive terminal.
Short circuit to ground: This is often caused by damaged cable insulation that is rubbing against the vehicle's body (ground, 0V), or by a faulty sensor that has an internal short circuit.
Translated on 28-08-2026, 14:55.
No new posts Error code 005399 / P1517 - Short circuit to ground Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Short circuit Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
This topic is locked, you cannot edit or reply. Explanation of MWB 4 at PD-ASZ (Synchronization Angle)? On-Board Diagnostics (OBD)
No new posts Looking for an explanation for a DPF error. Diesel Engine Technology
No new posts K&N Air Filter: Explained & Reviewed Diesel Engine Technology
No new posts Diode Tuning: Understanding Engine Characteristics. Diesel Engine Technology
