Check valve timing 2.0 CR with VCDS
docsnydor
Post15-09-2025, 14:54    Subject: Check valve timing 2.0 CR with VCDS Quote
Hello everyone,
To my shame, I have to admit that I'm not very familiar with VCDS, or haven't been for the past few years.
I replaced the timing belt, including the pulleys, water pump, etc., over the weekend, and I'd like to know how much I messed it up icon_wink.gif.
Audi A3 8PA engine code CBBB (2.0 TDI CR EA189)
What values should I look at?
I'd like to sleep a little more soundly; this is my wife's car.
Thank you and best regards.
David.
VG David
Polo 6R 1.6TDI CAYB
Audi 8PA 2.0TDI CBBB
Fiat Ducato 2.3
Translated on 08-07-2026, 19:19.
chli1976
Karma: +185 / -0   Thank you, like it!
dieselschrauber likes this.
Post15-09-2025, 19:25    Subject: Check valve timing 2.0 CR with VCDS Quote
Check if you can find a measurement for the synchronization angle; it was available for the PD models.
VCDS
Translated on 08-07-2026, 19:20.
Karma: +1343 / -0   Thank you, like it!
Post16-09-2025, 19:25    Subject: Check valve timing 2.0 CR with VCDS Quote
Attached is a Screenshot of the measurement values for the camshaft that can be found in the MSG using VCDS on my CJCD (EA189 Gen. 2). This should be similar for you. The meaning of these values is unclear.
You can check the quality of your valve timing adjustment by performing a mechanical inspection as described in the RLF (refer to the RLF for details).
- Manually rotated the engine in the direction of rotation.
- ZR voltage correct.
- KW stop installed on the drive gear.
- NW can be disconnected (mandatory).
- HDP is being blocked (Kür).
This ensures that the correct settings are sufficiently secure.
 File size:  30.82 KB
 Viewed:  2068 times
Translated on 08-07-2026, 19:21.
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adjusting timing and PD element for common rail diesel en... Troubleshooting & Guides
No new posts VCDS: Check Timing for VW/Audi 3.0 TDI Engines Diesel Engine Technology
No new posts Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Gasoline Engine Technology
No new posts VCDS: Check Compression Pressure On-Board Diagnostics (OBD)
No new posts 2.0 CR TDI Timing Belts... Volkswagen Timing Belts in gen... Diesel Engine Technology
