Hi, why is there a "X" emoji in the dialogue?
However, VCDS does communicate with the control units.
Because relatively few people can consider themselves the proud owners of such a cool car, the reset process has not yet been automated.
Automation is possible through (control unit dashboard insert/combination instrument).
Please provide the text you want me to translate from German to English. I will then give you only the translation, without any explanations. Also, please paste the "
Autoscan" content directly here instead of going shopping.
The reset process is similar across the same model generations and can be performed manually; see "Service reset via UDS" for details.
